Yep!This drive will work in a desktop yes?
Not really.Also, is there anything special I need to know about SSD's before I get one and start playing with it?
Only do a quick format NOT full format on install. After that run Windows Index bench, then make sure you turn off AUTO DEFRAG in windows. Then you should be set..
Why not defrag it? Isn't drives getting all kinds of fragmented bad for them?
install off a usb flash drive; its at least twice as fast
Why did you choose that kingston drive ?
What all programs should I install on my SSD exactly, and what files should I keep on it? Should I do a bran new fresh install of 7 - 64?
So yeah, junctions are what you want, tho if you right click drag and drop a folder from one place to another and pick symbolic link it works just fine too. Honestly some of the pictures on that page make it look harder than it is in practice.Hardlinks are a feature common to many Unix based systems, but are not directly available with NT4/W2K/WXP. It is a feature, which must be supported by the file system of the operating system.
So what are Hardlinks? It is common to think of a file as being an association between a file name and a data object. Using Windows Explorer, the file system can be readily browsed, showing a 1:1 relationship between the file name and the data object, but this 1:1 relationship does not hold for all file systems.
Some file systems, including UFS, XFS, and NTFS have a N:1 relationship between file name and the data object, hence there can be more than one directory entry for a file.
So, how does one create multiple entries for the same data object? In Unix there is a command line utility ln, which is used to create link entries for existing files, hence there are many file names, or so called Hardlinks, for the one data object.
For each HardLink created, the file system increments a reference count stored with the data object, i.e. it stores how many file names refer to the data object, this counter is maintained (by the file system) within the data object itself. When a file name referencing a data object is deleted, the data object’s reference count is decremented by one. The data object itself only gets deleted when the reference count is decremented to zero.
The reference count is the only way of determining whether there are multiple file name references to a data object, and it only informs of their number NOT there whereabouts.
Junctions are wormholes in the tree structure of a directed graph. By browsing a Junction a maybe far distant location in the file system is made available. Modifying, Creating, Renaming and Deleting files within a junction tree structure operates at the junction target, i.e. if you delete a file in a Junction it is deleted at the original location.
Symbolic Links are to files what Junctions are to folders in that they are both transparent and Symbolic. Transparency means that an application can access them just as they would any other file, Symbolism means that the data objects can reside on any available volume, i.e. they are not limited to a single volume like Hardlinks. Symbolic Links differ from Shortcuts in that they offer a transparent pathway to the desired data object, with a shortcut (.lnk), something has to read and interpret the content of the shortcut file and then open the file that it references (i.e. it is a two step process). When an application uses a symlink it gains immediate access to the data object referenced by the symlink (i.e. it is a one step process).
The easiest way to use symlinks is to use the Link Shell Extension (http://schinagl.priv.at/nt/hardlinkshellext/hardlinkshellext.html). You can then copy the files from the SSD to the HDD, and then use the LSE to drop a junction point on the SSD at the location where the files were originally. That way all the programs think the files are still on the SSD, but they are actually on the HDD. Then, if you want to put the game (for example) back on the SSD you just delete the junction point and copy the files back to the SSD. IT sounds complicated, but it is actually super easy, and works seamlessly.
And I believe that technically hard links and junction points are different, even though both are symbolic links. The one you want to use for moving files off the SSD is actually junction points, which looks like a file or folder on the SSD, but is actually mapped to the HDD.
From the link
Install LSE
Install to SSD like normal
Copy folder from program files to HDD
Delete original
Right click drag from HDD to original install location on SSD
From the menu "Drop As..." -> "Symbolic Link" (pretty sure regardless if file or folder you need to do symlink if crossing volume boundaries)
You're gonna have to reinstall windows anyway, I recommend installing LSE now and playing with it some, it's REALLY easy once you just see it in action.
I highly recommend doing a clean install on the SSD since a clone might not be properly aligned and won't optimize win7 for an SSD
