SSD mounting issue...
cschlik
I have an antec sonatta case with the slide out drive rails where the 3.5 hard drives are mounted from the bottom with rubber grommets and screws.
Here is the problem I am hoping someone knows a solution to... I need some Brackets that my SSDs will mount in and will mount into these drive rails. I bought a set of OCZ brackets but they only work with screws from the side... Any suggestions other than zip ties ;)
Thanks!
Ask Antec, I'm sure they have a convertor or something.
cschlik, any reason to mount it at all ? Ok, i have it secured by 1 screw in my case, just because i don't want it to destroy other components when i will move the case :D.
Universal mount:
I guess the only reason to mount is to not have them flopping around when I move the case...
