ssd life
Modder man
I have had my vertex for a few months now and its life is already down to %70, am i possibly doing something wrong. seems like it is going awefully quick.
It's life? Vertexs have a life gauge?
SSDs and flash memory is worn out by writes. Try to minimise the writes you do, by things like taking the page file off the disk can help.
where are you reading that 70% number from?
and multiple vertexes would be "vertices" i think :p
...and in doing so, remove one of the best performance gaining steps in moving to an SSD....
Per MS....
Should the pagefile be placed on SSDs?
Yes. Most pagefile operations are small random reads or larger sequential writes, both of which are types of operations that SSDs handle well.
In looking at telemetry data from thousands of traces and focusing on pagefile reads and writes, we find that
•Pagefile.sys reads outnumber pagefile.sys writes by about 40 to 1,
•Pagefile.sys read sizes are typically quite small, with 67% less than or equal to 4 KB, and 88% less than 16 KB.
•Pagefile.sys writes are relatively large, with 62% greater than or equal to 128 KB and 45% being exactly 1 MB in size.
In fact, given typical pagefile reference patterns and the favorable performance characteristics SSDs have on those patterns, there are few files better than the pagefile to place on an SSD.
If that SSD is degrading that quickly then something is wrong somewhere. Defragging would certainly hurt things, and is also my first guess.
I maximize the life of my ssd by leaving it on the shelf [/sarcasm]
Where are you getting this 70% figure, OP?
its been pretty much confirmed that writing to newer generation SSD's does not quickly wear them out. it is a widely circulated myth or just a misconception. lifetime is still measured in years not months even under heavy write conditions. slowdown and garbage collection are subjects different then physical wear and lifetime.
i found a program called SSDlife and it rated my ss at 70% life
no i have not been defragging, i did a bunch of the tweaks listed on OCZ's website when i got it to try to maximize life and performance
never heard of that program. its most likely a semi-arbitrary number that doesnt mean much. probably similar to programs that try to guess when your hard drive is going to fail, its as accurate as trying to predict a heart attack (aka- not very accurate).
most versions of windows automatically defrag in the background unless: you have windows 7 and it knows you have an SSD, or you turn off auto defrag. not sure what tweaks you did, maybe you already disabled it.
This? http://ssd-life.com/
That web site strikes me just like one of those "We'll fix your PC for you (right after we infect it with a problem so you need our $59 software to "fix" it).
Don't believe the bullshit, they just want to sell a useless product to a new market of unwary SSD owners.
i will double check when i get home but i believe i already disabled it, i am running windows 7
Doesn't Crystal Disk Info also provide some kind of "ssd life" indication? I'd check that.
Clicking on the Health Status button in Crystal Disk Info shows three different values which I'm assuming it uses to derive a Health %:
Reallocated Sectors Count
Current Pending Sector Count
Uncorrectable Sector Count
What values for those do you have for your drive, Modder Man?
My 80GB X25-M G1 has 168 days worth of power on, 5.56TB worth of writes and is still showing 100% :eek:
no idea if any of this is useful or not
CrystalDiskInfo 3.9.2 (C) 2008-2010 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Home Premium Edition [6.1 Build 7600] (x64)
Date : 2010/11/03 17:11:26
-- Controller Map ----------------------------------------------------------
+ Standard Dual Channel PCI IDE Controller [ATA]
- ATA Channel 0 (0)
- ATA Channel 1 (1)
+ AMD SATA Controller [ATA]
- WDC WD10 01FALS-00J7B1 SATA Disk Device
- OCZ-VERT EX SATA Disk Device
-- Disk List ---------------------------------------------------------------
(1) WDC WD1001FALS-00J7B1 : 1000.2 GB [0-0-0, pd1]
(2) OCZ-VERTEX : 64.0 GB [1-X-X, pd1] - ix
Model : WDC WD1001FALS-00J7B1
Firmware : 05.00K05
Serial Number : WD-WMATV1403958
Disk Size : 1000.2 GB (8.4/137.4/1000.2)
Buffer Size : 32767 KB
Queue Depth : 32
# of Sectors : 1953523055
Rotation Rate : Unknown
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ----
Transfer Mode : SATA/300
Power On Hours : 5898 hours
Power On Count : 1190 count
Temparature : 36 C (96 F)
Health Status : Good
Features : S.M.A.R.T., AAM, 48bit LBA, NCQ
APM Level : ----
AAM Level : 80FEh [OFF]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 200 200 _51 000000000000 Read Error Rate
03 250 228 _21 000000001D2A Spin-Up Time
04 _99 _99 __0 00000000055C Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 200 200 __0 000000000000 Seek Error Rate
09 _92 _92 __0 00000000170A Power-On Hours
0A 100 100 __0 000000000000 Spin Retry Count
0B 100 100 __0 000000000000 Recalibration Retries
0C _99 _99 __0 0000000004A6 Power Cycle Count
C0 200 200 __0 0000000001E6 Power-off Retract Count
C1 200 200 __0 00000000055C Load/Unload Cycle Count
C2 114 _98 __0 000000000024 Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 200 200 __0 000000000000 Current Pending Sector Count
C6 200 200 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 00000000004D UltraDMA CRC Error Count
C8 200 200 __0 000000000000 Write Error Rate
-- IDENTIFY_DEVICE ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 7A 42 FF 3F 37 C8 10 00 00 00 00 00 3F 00 00 00
010: 00 00 00 00 20 20 20 20 57 20 2D 44 4D 57 54 41
020: 31 56 30 34 39 33 38 35 00 00 FF FF 32 00 35 30
030: 30 2E 4B 30 35 30 44 57 20 43 44 57 30 31 31 30
040: 41 46 53 4C 30 2D 4A 30 42 37 20 31 20 20 20 20
050: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80
060: 00 00 00 2F 01 40 00 00 00 00 07 00 FF 3F 10 00
070: 3F 00 10 FC FB 00 00 01 FF FF FF 0F 00 00 07 00
080: 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00
090: 00 00 00 00 00 00 1F 00 06 07 00 00 44 00 44 00
0A0: FE 01 00 00 6B 74 61 7F 23 41 69 74 41 BC 23 41
0B0: 7F 40 5E 00 5E 00 00 00 FE FF 00 00 FE 80 00 00
0C0: 00 00 00 00 00 00 00 00 6F 65 70 74 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 01 50 E0 4E 36 01 8D F7
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 40
0F0: 10 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 29 00 00 00 00 00 00 00 00 00 A0 16 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 3F 30 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 0E 10 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 01 00 00 10 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 CA
-- SMART_READ_DATA ---------------------------------------------------------
000: 10 00 01 2F 00 C8 C8 00 00 00 00 00 00 00 03 27
010: 00 FA E4 2A 1D 00 00 00 00 00 04 32 00 63 63 5C
020: 05 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2E 00 C8 C8 00 00 00 00 00 00 00 09 32
040: 00 5C 5C 0A 17 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 63 63 A6 04 00 00 00 00 00 C0 32
070: 00 C8 C8 E6 01 00 00 00 00 00 C1 32 00 C8 C8 5C
080: 05 00 00 00 00 00 C2 22 00 72 62 24 00 00 00 00
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
0A0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 C8 C8 00
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 4D 00 00 00 00
0C0: 00 00 C8 08 00 C8 C8 00 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 84 00 A8 48 01 7B
170: 03 00 01 00 02 D6 05 00 00 00 00 00 00 00 00 00
180: 00 00 01 06 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 62
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 33 C8 C8 C8 C8 C8 C8 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 C8 C8 C8 C8 C8 C8 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 00 C8 C8 C8 C8 C8 C8 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AD
(2) OCZ-VERTEX
Model : OCZ-VERTEX
Firmware : 1.6
Serial Number : 517G54J79722CL3UZQXD
Disk Size : 64.0 GB (8.4/64.0/64.0)
Buffer Size : >= 32767 KB
Queue Depth : 32
# of Sectors : 125045424
Rotation Rate : ---- (SSD)
Power On Hours : 1497 hours
Power On Count : 105 count
Temparature : Unknown
Health Status : Good (69 %)
Features : S.M.A.R.T., 48bit LBA, NCQ, TRIM
APM Level : ----
AAM Level : ----
ID Raw Values (8) Attribute Name
01 0000000000000006 Read Error Rate
09 00000000000005D9 Power-On Hours
0C 0000000000000069 Power Cycle Count
B8 0000000000000034 Initial Bad Block Count
C3 0000000000000000 Program Failure Block Count
C4 0000000000000000 Erase Failure Block Count
C5 0000000000000000 Read Failure Block Count
C6 000000004C8CEF72 Total Count of Read Sectors
C7 0000000035FC9DCD Total Count of Write Sectors
C8 0000000001FD4E5E Total Count of Read Commands
C9 00000000015CDDDB Total Count of Write Commands
CA 0000000000424187 Total Count of Error bits from flash
CB 00000000003BA349 Total Count of Read Sectors with Correctable Bit Errors
CC 0000000000000000 Bad Block Full Flag
CD 0000000000001388 Maximum PE Count Specification
CE 000000000000043F Minimum Erase Count
CF 0000000000000734 Maximum Erase Count
D0 0000000000000612 Average Erase Count
D1 0000000000000045 Remaining Drive Life
D3 0000000000000000 Unknown
D4 0000000000000000 Unknown
D5 0000000000000000 Unknown
000: 5A 0C FF 3F 37 C8 10 00 00 00 00 00 3F 00 00 00
010: 00 00 00 00 31 35 47 37 34 35 37 4A 37 39 32 32
020: 4C 43 55 33 51 5A 44 58 00 00 FF FF 00 30 2E 31
030: 20 36 20 20 20 20 43 4F 2D 5A 45 56 54 52 58 45
040: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
050: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 01 80
060: 00 00 00 2F 00 40 00 02 00 02 07 00 FF 3F 10 00
070: 3F 00 10 FC FB 00 01 01 B0 0A 74 07 00 00 07 00
090: 00 00 00 00 00 00 1F 00 06 05 00 00 44 00 44 00
0A0: E0 01 00 00 6B 34 01 7D 22 40 69 34 01 3C 22 40
0B0: 7F 40 00 00 00 00 00 00 FE FF 00 00 00 00 00 00
0C0: 00 00 00 00 00 00 00 00 B0 0A 74 07 00 00 00 00
0D0: 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00
100: 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 15
000: 10 00 01 00 00 06 00 00 00 00 00 00 00 00 09 00
010: 00 D9 05 00 00 00 00 00 00 00 0C 00 00 69 00 00
020: 00 00 00 00 00 00 B8 00 00 34 00 00 00 00 00 00
030: 00 00 C3 00 00 00 00 00 00 00 00 00 00 00 C4 00
040: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
050: 00 00 00 00 00 00 C6 00 00 72 EF 8C 4C 00 00 00
060: 00 00 C7 00 00 CD 9D FC 35 00 00 00 00 00 C8 00
070: 00 5E 4E FD 01 00 00 00 00 00 C9 00 00 DB DD 5C
080: 01 00 00 00 00 00 CA 00 00 87 41 42 00 00 00 00
090: 00 00 CB 00 00 49 A3 3B 00 00 00 00 00 00 CC 00
0A0: 00 00 00 00 00 00 00 00 00 00 CD 00 00 88 13 00
0B0: 00 00 00 00 00 00 CE 00 00 3F 04 00 00 00 00 00
0C0: 00 00 CF 00 00 34 07 00 00 00 00 00 00 00 D0 00
0D0: 00 12 06 00 00 00 00 00 00 00 D1 00 00 45 00 00
0E0: 00 00 00 00 00 00 D3 00 00 00 00 00 00 00 00 00
0F0: 00 00 D4 00 00 00 00 00 00 00 00 00 00 00 D5 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1D
170: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F5
010: 00 D8 05 00 00 00 00 00 00 00 0C 00 00 69 00 00
050: 00 00 00 00 00 00 C6 00 00 11 DA 8C 4C 00 00 00
060: 00 00 C7 00 00 37 69 FA 35 00 00 00 00 00 C8 00
070: 00 EF 4D FD 01 00 00 00 00 00 C9 00 00 5B BC 5C
080: 01 00 00 00 00 00 CA 00 00 72 41 42 00 00 00 00
090: 00 00 CB 00 00 36 A3 3B 00 00 00 00 00 00 CC 00
0C0: 00 00 CF 00 00 32 07 00 00 00 00 00 00 00 D0 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 73
I've seen life goes pretty quick on those OCZ drives. Doesn't like that at all. My Intel is still going strong with 100% after 12 months of use.
so should i just not worry about this or is there a problem here that i need to fix
