SSD Help
jebro
Hi,
I just bought an Intel SSD and am having trouble configuring my system.
Basically my setup is:
2x1tb seagate 7200 rpm sata drives in RAID0
1x80gb intel SSD
gigabyte 890gpa-ud3h motherboard
I installed Windows onto the SSD, but on boot it would say 'loading operating system...' and never advance. Any help would be appreciated.
Thanks
And if that doesn't work, you may need to leave the other drives unplugged and re-install Windows. If you have previous OS drives attached when you try to install on a different drive, Windows will sometimes screw up the install and leave the bootloader on the old drive.
Exactly.
Hopefully a reinstall on the SSD without the array being connected will fix your problem.
Good Luck!
It's possible to correct this problem with the bootsect command, available on the windows vista/7 DVD.
