SSD Adapter
I don't see why you couldn't use any 3.5" conversion kit as long as it has screw holes that line up with a standard 3.5" HDD. Worse case, it doesn't fasten correctly in the tray, but it should still stay in via friction since there is no vibration.
I thought about this after. I think my case has slots just for SSDs. I think a normal adapter would work fine.
