Falcon_CMH
- Feb 28, 2009
Great Board good luck with it
Yeppers, have a new ZN8A coming Wednesday from the Egg.
you know, tobit's case is really interesting since he's using the exact board and RAM that ran a couple of L5640s up to something like 215 bclk. Clearly, those CPUs are holding his OC back.
I didn't know that Sazaneyes. That's good info. I have a single X5650 in a X58 mobo that is unstable at anything about roughly 3.6ghz. Still dialing it in.My SR-2 with X5650s is currently running at 3.78GHz (172x22), and it won't go any higher. Some Xeons just don't like high BLCKs. My other SR-2 with L5640s will run at 200 BCLK as long as I keep it cool.
tough break on the CPUsIt's definitely a cpu problem for me. I put my E5530s back in and I can run bclk of 205 in windows and 185 in Ubuntu no probs. Even though Ubuntu is less tolerant of the bclk I get more production in Ubuntu so I'll stick to this on the Sr-2. I'm going to put my E5649s in the Z8NA and run it stock there. I'm good with that.
I hope the Z8NA treats you better
Your old pair of E5640's. Was thinking of trying the old CPU swap and running them in the SR-2 instead but IDK.Tobit what CPUs are in your z8na?
they run at 4ghz pretty easyYour old pair of E5640's. Was thinking of trying the old CPU swap and running them in the SR-2 instead but IDK.
No and no. Still on air, temps haven't gone above 66C during folding regardless of voltage settings. When I first started playing with them around 4 GHz and 4.2 GHz, I was running in the mid 70's.do you have your water blocks on already? do you think it's a temp issue?
My old L5640's used to run all day at 3.8 GHz, never should have sold them.I think I can push the L5640s harder too, I just haven't had time to work on it.
Geez 152k. I need to switch to Linux.
Posted via Mobile Device
