Splat goes the computer
Kaizen
Ahoy,
My computer is being a turd and while I hope it's not my motherboard, I wanted to put my issue out there to see if anyone has had the same problem...
This doesn't happen every time, but sometimes when I go to boot my machine, it turns on but no signal is sent to the monitor. It just sits there blinking at me while my computer fails to do anything useful. Then, if I turn it off and leave it to think about things for a while and come back to try again later, it will usually boot but tell me the following:
"Warning, the previous performance of overclocking is failed and the system is restored to the default setting. Please press any key to continue..."
After pressing something it'll boot the rest of the way, but the picture in the monitor will flicker and scramble intermittently. Fun. Then, if I restart it again, it'll either restart normally or we'll go back to the first step of it not booting at all. It's strange though, because if it decides to work at this point, it will function flawlessly.
Are there any hardware diagnostic programs that you can recommend that would check my tower's innards for errors? Any ideas as to what may be the problem?
If it's helpful, my motherboard is as follows: MSI K8NGM2-FID mATX S939
GeForce 6150/6100 + nForce 430/410 Chipset based
If you need any more info, please let me know. If you couldn't tell already, I'm not exactly a computer specialist here but I can usually find my way around.
Thanks and I hope to hear from you soon
could be a bad cmos battery,or overheating. beyond that bad/dieing cpu or motherboard.
try running prime95 or a memtest for like 12-24 hours and see if errors out on either.
First suspects are a dead CMOS battery, failing PSU or a bad connection somewhere.
Try cleaning and rebuilding the PC, dust works its way into connections through heat cycling.
Maybe even a combination of the above.
what it looks like to me is that the overclock is not stable on cold boot but it stable on a warm boot.. same problem i have with my phenom II 940 and biostar 780g motherboard..
but a dead cmos battery is a possibility as well..
I have the same motherboard and sort of the same problem. It happens every couple days I turn it on and the lights come on, fans spin and nothing happens. I press the reset button and sometimes it restarts sometimes it wont. I power it off then back on it will either turn on or do the same thing again but eventually comes on. Doesn't give me any error messages it either boots or does nothing. One day it didn't want to come on so I hit the computer and of course hitting shit always works. After that happened I went and made sure all the connections were good and all my cards seated properly and it hasn't happened since.
Sounds like a PSU problem. I had very close to the same problems and I RMAed my PSU and it fixed them all.
It amazes me that hitting stuff actually works a lot of the time. Never underestimate the power of a good whack ;).
if it works for the Russians, it should work for everyone else.
lol was going to say the same thing... one of the best parts of the movie Armageddon..
Lev Andropov: It's stuck, yes?
Watts: Back off! You don't know the components!
Lev Andropov: [annoyed] Components. American components, Russian Components, ALL MADE IN TAIWAN!
Lev Andropov: This is how we fix problem in the Russian space station!
[hits panel with tool]
I have a little 15" Dell LCD monitor that starts flickering every now and then ... a couple solid 'thunks' to the side of it's head and kind of reboots itself , displays the Dell logo thingy and then is just peachy until it's next flickering episode :p
lol, I had a monitor years ago that used to spaz out on me every so often.
The screen would flicker like a mad thing until I tapped it on the side.
As time went on, it was still usable but the taps needed to make it work got harder.
When it got so I had to slap it so hard that my fingers hurt, I got my shoe out.
What a relief, much easier.
It didnt last much longer :)
