Spec question
jfharper
if a motherboard says this::
CPU Socket Type Socket 939
CPU Type Athlon 64 FX/Athlon 64/Athlon X2
FSB 1000MHz Hyper Transport (2000 MT/s)
does it mean it will match this:
AMD Opteron 170 Denmark 1GHz FSB 2MB L2 Cache Socket 939 Dual Core Processor
is it only the pins I need to match up?
yeah the socket types are what really matters. A socket 939 opteron should work in any socket 939 board that supports Rev E's and such, even if they don't explicitly state opteron support. It's basically a rebadged Toledo or San Diego, depending on whether it's a single or dual core opty.
I'm sorry for my ignorance...what is Rev E's and how do I check that a MB will support that...also you said it depends on whether it is a dual or single core opty, is there something on the MB I should check to make sure it can handle dual?
As long as you have the latest bios, you should be fine with Rev. E CPU's ;). If you said what board you were looking at you would get more exact answers and probably some anecdotal help :).
Here you go...
BIOSTAR TForce6100-939 Socket 939 NVIDIA GeForce 6100 Micro ATX AMD Motherboard
AFAIK, that board works fine with the Opteron. Might want to double check in the SFF section of the forum. There is a whole thread dedicated to this board there. You can get more direct answers as to what bios they use, etc.
right on...thanks. I guess I'm a bit overwhelmed by the boards and stuff out there for building my render boxes...which brand to go with, how much to spend, do they play nice together, etc. But I'll keep checking out the forum for specifics...thanks.
