jonneymendoza
- Sep 11, 2004
Hi, can anybody help me spec a cheap intel gaming htpc?
i already have a old seasonic PSU i will use as well as a case, OS and graphics card. i mainly just need a cpu, mobo and ram to start me off.
i want it to be fast enough to play and record 720p and 1080p videos without any lag. will a dual core do? i want a mobo where it offers me a bit of an upgrade path to upgrade from a dual to quad core if i need the extra cores later on.
trying to keep it all under £200 for now. Will my old seasonic PSU which is around 400w work fine on a dual core? it currently poweres my pentium 4 lol.
if not, might need to toss in a PSU on that £200 budget. The GPU im going to install on it is a 260gtx. ALso will be attaching 3 hdd's as well and around 2-3 case fans if that helps narrow the psu spec down.
fed up with my pentium 4. struggling to play 720p let alone 1080p. i just need something to get me going. Need it to be a reliable brand so not too cheap stuff.
cheers again
cheers again
