I recently moved into a bigger place and in the process of re-setting up my tv and speakers. The wire I was using previously seems to be a little short so I will likely end up buying a spool of speaker wire and re-cut custom lengths.
Since it's been so long since I bought speaker wire, I have forgotten a few of the basic points.
Stranded or solid core?
What gauge is appropriate? I'm prob. looking at 20-35 foot lengths max.
It doesn't need to be fancy wire. The speakers themselves are relatively simple (Klipsch 5.1 Ultra system) but I may in the future upgrade to a more robust system. I think the 5.1 ultra amp puts out in the neighborhood of 80W max RMS per satellite (if that matters any).
Lastly, if I have the opportunity I would like to buy white speaker wire so when I lay it at the edge of the carpet near the wall moldings, it blends in better. A brief search of monoprice didn't really turn up anything though so is there a better source for speaker wire?
Thanks
Ruahrc
Thanks
Ruahrc
