Child of Wonder
- May 22, 2006
I've been finishing my basement and installed some speaker wire behind the walls for my rear speakers to be mounted near. I ran 14 gauge wire (and one run of 12 when I ran out of 14) but all the hardware stores I've checked only sell speaker wall plates that support up to 16 gauge wire. My wire is too large to fit into the hole on the tabs on the back.
Can I simply solder the wire straight to the tab without using the hole? I doubt this will degrade the speaker performance but just wanted to know if anyone has done this?
Or does anyone know of any good speaker wall plates that can handle up to 12 gauge wire?
