This is my first worklog, so the pictures aren't all too good. Next time i'll take better and more detailed pictures, but here is what i got...
Like most computer hardware enthusiasts, I tend to collect used parts and pieces from friends and use them for whatever project I feel like working on at the time. So for a while I had three desktops just in my bedroom. One all-purpose/gaming custom computer(my second casemod) running Win XP(2.4 Ghz, 1gig RAM), one file storage/testbed Dell running Win2k(1.8 Ghz, 256megs RAM), and another Dell running whatever flavor of Linux I happen to have installed(1.6 GHz, 256megs RAM). One day I stumbled upon Jeffrey Stephensons site www.slipperyskip.com and his Humidor Cluster. The look of all those mobos stacked on top of each other got me interested in small clusters. So I started looking into easy cluster solutions. I finally decided on ClusterKnoppix (clusterknoppix.sw.be). Its a LiveCD cluster solution. Boot a couple of computers on a LAN from the CDs and BAM! you have a cluster. With a little bit of work you can get the LiveCD to install clusterKnoppix onto the hard drive. I had a lot of trouble getting drive permissions figured out and all, but that might just be me being an idiot. After clearing up all the hardware issues, I had a three-node, auto-balancing cluster running. Then I turned it off. And rebooted. And one of my Dell motherboards died.
I hadnt used it much in a long time and so it was toast. Down to two. I realize that a two-node cluster isnt much of a cluster, but I wanted a project to work on, and I was tired of having so much space taken up by computer cases. So I decided to build a two-node cluster in a custom case. I decided to use a threaded rail system similar to the humidor cluster. I wanted keep access to XP and 2K, while still having a cluster. Since I had few spare hard drives, I decided to set-up dual-booting on both mobos. Boot to windows and I had a basic single system. Boot to linux and I had a quick cluster.
First was the testing. After I downloaded the latest disk images and burned them, I booted both comps. One KDE loaded, I opened a terminal window and ran knoppix-installer. After some trouble formatting the hard-drives right, I got them both running. Once I had the software installed and working, i began the hardware work.
Here are the computers i plan to tear apart.
To test the configuration of the cluster i put the first mobo on the rails and booted it up with it's bare-bones components.
I finally decided to mount the mobos above the PSU and HD brick.
Because Dell uses non-standard hardware(arrrrgggg!) I used the metal tray from the original dell case to hold the mobo and then mounted the tray on the rails.
The tray had a metal latch and rear component panel that i cut off with my dremel.
More to come....
More to come....
