elm669
- Jul 8, 2003
Soyo P4I865pe plus Dragon 2 V1.0 with a celeronD 320 2.4ghz
I got a call from my dad saying that his computer shut off and won't turn back on, So I get home and start messing with it. When I flip the power switch the fans turn on for a second then go off and the powerlight on the mobo turns red.
Here's what I've done so far:
run it outside the case
run it with 3 different power units
run it with 2 different sticks of ram in all the slots
run it with 2 different cpus celeron D 320 and northwood celeron 2.4ghz, 2 different heatsinks and tried running it without a cpu.
reset the bios
made sure the ram works in other computers
made sure the cpus work in other computers
made sure the psus worked in other computers
tried multiple videos cards, agp pci, ...
made sure nothing was burned up on the board, everything looks fine as usual
made sure no caps were blown
made sure to try a combination of components above in every possbile configuration
Even after changing everything all it will do is bump the fans over like it has a short. Regardless of the psu I used the only way I got the fans to spin was to remove the 4 pin atx12V+ connector but it wouldn't post.
Can anyone think of anything I'm missing? anyone had anything similar happen?
I personally think that the mobo is dead from a short somewhere but am running it by here because It's 1:30 in the morning and I'm dead tired.
reset the bios
