Got a problem I was wondering if anyone can help out with:
I have a set of Logitech X240's, they are plugged into a power bar and into the wall.
I also have a mini-fridge for drinks and what not in my room, plugged into the wall, not on the same socket, but most likely on the same fuse as the speakers.
Everytime the compressor on the fridge kicks in, and shuts down, theres a spike in the power in my room and the lights dim for half a second.
My problem is when the compressor kicks in, my speakers have a loud sound that come out. Its really annoying when i have the speakers on but nothing going thru, so all of a sudden i'd get a loud "bang" sound.
I wanted to ask if this is 1) causing any damage to my speakers, and 2) is there an easy way to avoid/fix the problem?
