I can't seem to get the sound working in my new EVGA motherboard (which I got free with the 7800 gt I highly recommend it ). I updated the latest nforce4 drivers including the audio but still no go. Thanks in advance.
Yeah, most bioses will list onbard audio as auto or disabled.
And I'm sure you already checked the obvious things like speaker config, wires plugged in correctly, volume up, etc.
Yeah I checked the bios and its enabled so I'm not sure what the problem could be. Its plugged in, drivers are updated and sound is up high of course. Any other ideas?
bump cause I could really use some help. I'm using realtek ac97 audio btw. My computer detects it and says I have sound, my speakers work with my other pc. I have two seperate sets of plugs for the speakers so I doubt both could be bad so its gotta be something really dumb but I can't think of it.
Yep uninstalled and reinstalled the realtek drivers about 4 times, Tried reinstalling the original drivers, tried using different speakers, did just about everything I, the tech support folks, and the net could think of so it has to be something retarded. I gave up and just bought a sound card and it works great now. Thanks though.
