Sound cards that work with vSphere?
madcoder
I want to know who has had success with either sound cards or usb to spdif interfaces with vSphere. I have a vmdirectpath capable system. I tried a Xfi Titanium HD, and did manage to get the analog outputs to work but ONLY with Windows 7 builtin drivers. Any of the Creative drivers were a no-go. I need as high of quality output as possible.
I have seen a few posts around the internet asking this question before, and those with standard responses related to not being what vSphere (or etc.) is for need not apply. I do have a valid use case where it would be beneficial and reduce the number of systems I run, and would like for some audio applications to also run on my vSphere server. Yes, vSphere is not really built with this in mind, but I am not interested in hearing these kind of responses, but rather if anyone HAS had success with higher end / decent sound cards.
An Xfi Go Pro was a no go. It simply would not work. A cheap Syba (2 channel C-media based) USB one works, but I was looking for something higher quality. Actually, I am more looking for spdif out, and let proper audio hardware do the decoding, or just a DAC with USB input that will work fine with vSphere. As such hardware items of good quality are very expensive, I was hoping that someone else using vSphere in such a capacity would respond with what hardware worked ok for them.
I hate to resurrect an old thread, but someone asked me about an update on this, and thought that I might as well share the knowledge with everyone.
So far, I have good success with this simple SYBA USB sound stick.
http://www.amazon.com/Syba-SD-CM-UA...S6CS/ref=sr_1_1?ie=UTF8&qid=1330446857&sr=8-1
http://www.amazon.com/Syba-SD-CM-UA...ef=sr_1_1?rps=1&ie=UTF8&qid=1330367744&sr=8-1
I had tried some Creative ones, and none of them ever worked.
Then, there are 2 other solutions...
One is to use a USB network device server/sharing device of some kind to put the USB sound card there. That worked, but sometimes the sound might skip a bit.
The other solution that I thought up was using Airfoil software by RogueAmoeba to connect a VM to an Apple Airport Express, which is then connected to a stereo/amplifier. This works OK, but there can be some lag to sound starting up.
