I have a huge problem with my recently purchassed Sound Blaster Z. The sound is so bad that it reminds me of my great grandfather's old 1946 GMC pick-up with a blown speaker. There is no bass at all, unless I am watching a video on YouTube or anything else that uses flash.
Here is an idea of what has happened so far:
When first installed, it worked great until I tried to game. Then the sound became choppy and the video frame rate dropped to a slide show. I had used the secondary port x16 PCI-E Buss. So I moved from my secondary x16 Buss (my video card in the primary slot) to my primary x4 slot (there was nothing in the secondary slot at that time). Please note that according to the documentation it should have worked fine in the secondary x16 slot.
Then I got a huge nasty buzzing sound that almost knocked out any other sound the card attempted to make. The RFI shield is on the wrong side of the card to stop the interference from the proximity of the video card, also the driver did not automatically reset itself to the new slot, it had to be manually set to the second Sound Blaster Z.
I uninstalled the driver, used DriverCleaner.net, shut down the computer and removed the sound card, wiped everything creative from the computer and started over.
Dozens of installs and a long set of e-mails with support later the only time I get acceptable sound is when I am watching something off of the web that uses Flash (like YouTube). Creative Support says they can not reproduce the issue. Everything I play on my computer sounds tiny. The sub-woofer simply does not cut in like it should.
I am seriously thinking of formatting and reinstalling windows, but I really dont want to do that nor should I have too. I am considering asking for a refund...
Can anyone help?
