sorry
Status
Not open for further replies.
Mikey20
sorry for another thread like this but i need some opinions my friend is on a budget and he can't unpgrade he wanted to know if he will be able to run half-life2 ok....
Intel Pentium4 1.5Ghz
512mb PC2100 Ram DDR
GeForceFX 5200nu (slightly overclocked)
thats his system specs.
We don't know, but preliminary benchmarks say not at a decent resolution.
You'll be on the 3x path, and will have to yank that resolution down to get it playable. Especially with that 1.5ghz P4 (that's the original willimette core...)
jup, he should have no problem running it at 800x600 with eye candy turned down
Your the HL2 Genius. YOU figure it out.
Screw HL2, I want to know if it will run HL3.
Not sure, the 5200 is a terrible card, even for the budget level, and the RAM and processor are older models. If he was able to, I wouldn't expect anything higher than 800x600 with some visual quality compromised.
Status
