Sorry Another help me build a new rig thread
Dende
I'm sorry I know these aren't very popular but I could use some help.
I am trying to build a good gaming system with as little money as posable BUT I don't want to sacrofice stability/performance too much. Also keep in mind I am a HUGE fan of windows XP (plus I have a site license so I don't have to pay for it LOL).
This is what I have so far.
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK - Retail for $54.99
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail for $136.99
Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500 - Retail for $187.99
Total price so far is $379.97
I still need a case and power supply (I have NO idea which one), Video card and hard drives.
I want to be able to play GTA4 (after the fix all the problems) AND raid 5 is a must for me :)
I am a VERY casual gamer the only game I play alot is WoW but I realy like the GTA series so I wanted to try it out at least once.
I have a couple of issues also I heard that the stock HSF for the E8500 may not fit on this system board if that is the case what HSF should I pick up??
Next I want to run 6 hard drives (2 for system mirored and 4 for storage raid 5) The 2 hard drives I will get right away the 4 storage hard drives I will pickup my next pay check lol. I will need a case and power supply what will handle that kind of load. I am thinking along the lines of 500gig for system and 1.5Tb for storage.
My last issue is the memory I heard that there was some compatablity issues with some ram and this system board has anyone heard of this???
Well again sorry for yet another help me build a system thread but there is no other site I trust to help me with builds I ALWAYS check here before buying ANY hardware.
If I have looked over anything or forgot anything important in a build please let me know :)
Then you really want a Quad and not the E8500. Read [H]ard's recent performance review of GTA4. That says it all for me.
You should have put this thread in General Hardware. I suggest you PM a mod or admin and ask them to move it, because you probably won't get much help here.
I took your advice and did just that :)
Thanks for moving this there where it belongs :) So guys and gals any ideas??
Which size/resolution monitor are you using?
Have you bought anything yet?
RAID 5 is a must? You may want to rely on a RAID card -- and time that purchase for around the same time as the other four hard drives.
Are you going to use RAID 0 for the two 250GB hard drives?
Where did you get the information that the stock HSF won't fit the GA-EP43-UD3P from?
Just recently purchased a system for myself via NewEgg. Prices are in Canadian:
NEWEGG.CA Components
AMD Phenom 9850 2.5 GHz Quad-core 125 W --- $181
OCZ Reaper HPC DDR2-1066 Dual-channel 4 GB (2 x 2 GB) --- $82 - $30 mail-in rebate = $52
JetWay JHA04-LF AM2 AMD 790FX ATX AMD Motherboard --- $119
POWERCOLOR AX4850 512MD3-DH Radeon HD 4850 512MB --- $171 - $20 mail-in rebate = $151
TOTAL: $553 - $25 instant discount (for bundle) = $528
TOTAL (After rebates): $528 - $30 - $20 = $478
You're in the States, so your total should be even lower, and my above quote includes a Radeon 4850.
*QUESTION* What the hell are you thinking running RAID5? Unless you have a dedicated LSI Logic, AMCC, and/or Adaptec card with dedicated processor, you're foolish. The onboard RAID5 solutions are performance bottlenecks, and tax the CPU, especially when using 7200 RPM SATA. You're much better off running RAID10, and sacrificing the additional capacity that RAID5 would otherwise give you. I'm a systems architect, and I never run RAID5 unless necessary... ...and I usually do it only when I have more than 4 disks in a stripe-set, 'cause otherwise, speed is horrible (especially writes, because the parity info must be written to all disks and calculated in real time). Reads can sometimes outperform RAID1, but only in large RAID5 disk sets... ...not small sets with only 3 or 4 disks.
I have a Samsung 24in SyncMaster 2493hm (and I LOVE IT lol)
Raid 5 because I currently have over 1TB of anime that I have stored and I want to have some sort of data protection (currently I have none).
I was thinking of finding the least expensive (Price,performance/gig) hard drive as the pair for raid 0.
I did not read that the stock fan would not fit on the GA-EP43-UD3P just that in general the stock fan has caused problems on "some" motherboards my question was more to find out IF the motherboard I listed would have problems or not :) :)
As for the raid 5 performance I am only looking at it as a storage solution not as a performance solution. I want to be able to replace a hard drive if it goes bad and it rebuild that hard drive without the loss of data. I have spent several years collection unlicensed anime from all over the world (although mostly Japan) and I have never thought about a backup solution. I thougth about just geting a network storage box. I have seen some at microcenter and online but I thought it would be cheaper to just do it when I build this new system.
Two more questions....
What's the most you're willing to spend on this system? (Give us a dollar amount, as people's imaginations tend to get wild without some sort of "guidance.")
(Since you didn't answer this the first time....) What have you purchased already?
Sorry hehe I have not bought anything yet. I an looking at $1000 total (I can go up a bit but don't want to) I'm going to spend 500 now and 500 next pay to pick up the rest of what I need. Also I am NOT going to get the storage drives right away I am going to add them AFTER the system is built so the 1000 is for the system only and not the storage I will spend more on it when I am ready to setup the storage.
So to sum it up 1000 for the system total split in two $500 orders. and another additional $500 or so in storage after its built in about 4 weeks.
I do want to get this new system for as cheep as possible thought thats why I didn't setup an i7 setup I just can't see paying $300 bucks for JUST they system board :p if they where half the price they are now I would have setup an i7 system but its just too much of a premium at this time IMO
The stock HSF will be fine with that board, and you won't have any heat issues unless you plan on overclocking. If you do, then I recommend you purchase a better aftermarket cooler such as the Xigmatek HDT-S1283, or OCZ Vendetta 2.
Here's the $1000 build:
$57 - Cooler Master Centurion 690 ATX mid-tower case
$7 - Two Yate Loon D12SL-12 120mm case fans (for Centurion 690; you may want more)
$122 - BFG Tech ES-800 800W power supply (free shipping)
$130 - Asus P5Q Pro Intel P45 ATX motherboard
$190 - Intel Core 2 Quad Q6600 (free shipping)
$46 - Xigmatek HDT-S1283 CPU cooler & ACK-I7751 retention bracket
$40 - G.Skill 2x2GB DDR2 800 CL5 RAM kit (free shipping)
$70 - Western Digital Caviar Blue 640GB SATA HDD (free shipping)
$26 - Samsung SH-S223F SATA DVD burner (free shipping)
$240 - HIS H487F1GP Radeon HD4870 1GB video card (free shipping)
$928 - Subtotal (not including shipping, taxes, or rebates)
There's a reason why I went with the WD6400AAKS instead of two WD2500AAKS drives -- with the WD6400AAKS, you get near-Raptor performance for less than it would cost to get two 250GB hard drives (two at $50 each... you do the math).
The P5Q Pro motherboard that I chose has many of the same features as the EP45-UD3P: dual x8 CrossFire, eight SATA 3GB/s ports, onboard RAID 0/1/5/10, and dual GbE ports. I also picked up the Xigmatek HDT-S1283 (with its retention bracket), which will perform quieter and run cooler than the retail HSF. (If you're really trying to pinch pennies, you could omit the aftermarket CPU cooler... but if you plan on overclocking the processor, keep it.)
Though you could switch out the Q6600 for the E8400/E8500, more games (including GTA IV) are being optimized for use with quad cores. You could also easily overclock the Q6600 to (at least) 3GHz without it affecting its lifespan -- and that would negate the main advantage the dual-core Wolfdales have over it. Even for overclocking, you won't need RAM faster than DDR2 800 for the Q6600 -- so that was an easy way to save some money.
The 1GB HD4870 was chosen to maximize your gameplay within your $1000 budget. However, you may want to get a second card -- or, better yet, a newer card that would outperform a HD4870 CrossFire setup -- later on for newer and/or more graphically demanding games. On that note, I chose the BFG ES-800 since it will have enough power for an HD4870 CF setup and six SATA hard drives.
Since, with the inclusion of the WD6400AAKS instead of two WD2500AAKS drives, you aren't using the onboard RAID controller, you could save yourself some money by going with four 750GB-1.5TB hard drives for the RAID 5/10 configuration. But I've heard that it's better to go with a dedicated RAID controller card for a RAID 5 configuration... so I'll let someone more knowledgeable than me (in that area) make the recommendation for you.
Just an FYI: RAID IS NOT BACKUP! Data in a RAID 5 array can still be infected, accidently deleted, modified, or corrupted. Use DVDs, a NAS/File server, or external hard drives as backup, not a RAID5 array. All RAID does is guarantee uptime for your data, not protection or backup of your data.
WOW you guys are AWESOME :) :) :) everything looks great but now I have LOTS to think about LOL I'm not in a hurry to get this built but I do want to start ordering tomorrow. I am going to go ahead and order the case and power supply first because it has no baring on the actual performance of the rig.
Also I am thinking that I may go ahead and omit the raid 5 part and go with a NAS I found one from WD that is 2TB setup with 4 drives that can be replaced (in a raid 5 setup) as to as stated allow for off system backup AND data retention.
In that case, go with a cheaper power supply... unless you plan on going with an HD4870 CF setup within, say, the next six months or so. (Wait any longer and you might as well wait for the newer, better, video cards to come in. Then again, you could always sell your old/current card to help recoup some of the costs.)
Reread Danny's post. I know that you have a lot of anime saved up -- but it seems as if you're ignoring the most important part of his comments.
That would be a good way to go. Most good NAS boxes also come with software that will automatically back stuff up for you, so it'll be really easy to get that set up. Running RAID5 on the NAS does seem like a bit overkill to me though, since you'll already have the data in two places. It's certainly not a bad thing if you're prepared to spend the dough, however.
Well I'm heading out to pick up a case and power supply. I'll let you know what I find :) :)
Also are there any rumers of price drops on the i7 systems any time soon??
Well I got an E8400 for FREE!!!!! Reatail so I built a system around it :p as soon as I have it all up and running I'll let you know what I got. I'll get the Q6600 once I get a change (and my CC cools off :p)
Just making sure, but you do plan to have your data on both your system and on your NAS, correct? If so, then you're all set. If not, plan for it. :p
Yes I will have two working copies :)
Also I need some more help LOL I got the new system up and running but the stock HSF SUCKS ASS!! roflmao (although I am running stable at 3.4G:p) Can someone recomend me a few HSF's that won't break the bank. I will be upgrading to a q6600 in the future but I am VERY happy with 3.4ghz at this point I just HATE the look of that crapy ass fan LOL
tiraides gave you a great recommendation for a heatsink already:
I saw that but is 46$ realy a good price?? (I'm not trying to belittle anyone I just realy don't know what a good price is for a HSF) I was wondering if there where any others that maybe a little cheeper :)
You can knock off the extra bracket if you want to save some money. However, there is no better heatsink for the price.
AWESOME GUYS :) I just added both the HSF and brackets I also added some Artic silver :) As soon as I get it all setup I'll update everything I got. You guys where a HUGE help :)
Thanks for all the help
Code:
[ img]http://www.link.to/your/image.jpg[/img]
Just don't include the space between the "[" and the "img". I only put that there so it wouldn't try to post an image. :)
Code:
Thanks man as soon as I get some up I'll post them :)
If you need a place to host your images, imageshack, among others, is free.
