Abstraight
- Jul 21, 2017
Okay so I have a Sony GDM fw900 and use it very rarely like once in 2 months or so.Now the last time I used it was maybe 1.5 month ago and it worked perfectly. Yesterday I turned it on and was presented with the problem shown in the picture below. As you can see these horizontal bars appear on dots/artifacts that are different colors from the rest and if I move objects of different colors around the bars will folow. It makes me believe its not a tube problem itself but something in the signal processing route (neck-board) maybe a failing IC,transistor or bad capacitors
I heard that when these monitors arent used regulary they can develop bad capacitors, which would deff. be able to cause problems like this besides waked out geometry
