A Great friend to the HardForum with a great kid that he is trying to get a scholorship to continue his schooling. Please give hime a vote! Only 24 hours left! Thanks.
Nope . You're screwed , replacing the CCFL for individual models is pretty much not possible. Unless its under warranty (which it probably isn't) you are gonna be shopping for a new panel
But, since the panel is probably pretty much worthless to you anyway, you might want to pop it open and have a look.
The best scenario i can see for you is to go on ebay and find a broken panel of the same model and try to swap the parts without breaking them. It's important to know though that LCDs are stupidly fragile once you have the case off.
