Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I went from a Sonata 1, which is basically the 2 without air ducts, to a P150. Features I subjectively prefer:
- No door
- Hidden drive bays
- White color
- LEDs aren't as bright, the sonata used to light up my room at night
Objectively:
- HDD suspension system, but only allows three drives in this config
- Easier wire routing due to removable panel on motherboard side, and hooks for wrapping wires
- Sound dampening plastic on 3 of four inner panel sides
- Greater airflow than the P150
Yeah - as much as I like the Sonata the P180 experience is leading me towards the P150.
Some people (and from what I've seen on SPCR) have been mentioning problems with the PSU. I do note it's different from the Sonata II's... Any experience on that point, someone?
I have 2 Sonata cases, but since I purchased them I am overclocking more agressively. The airflow is insufficient. I found heat issues even when not overclocking (much). The P-180 will be far better with air flow. The 900 will be even better for air.
I do not aggressively OC in my Sonata cases, but they became useless to me for upgrading. Where as if I had done P-180 or 900 (unavailable at the time) I would have still been able to use them.
As to the Wave Master in my sig... It is also a pig for air. (slow learner)
I've had the P150 for 4-5 months I believe, no problems with the PSU. If you read into it, I think the PSU problems were with the initial batch or something. I was worried about this as well but with research I found out that the new ones were fine, I don't remember the details though.
