- Apr 12, 2003
When do you guys predict sandy will be in stock at newegg? And can I carry over my DDR 1333 that oc's good to a sandy bridge good?
WinRAR had a significant difference and the rest, not so much from those days.Yeah i know i just meant does it make a huge difference on sandy as opposed to the old 2.4C days.![]()
well for starters there was a review done that there isnt a noticeable difference between 16x/16x vs 8x/8x, if you must have 16x/16x then you need to steup to s1366 or wait for the replacement of s1366, s2011
I honestly don't know what people are expecting. In resolutions used for gaming, rendering is the bottleneck, not the transfer of geometry data to the cards. Worst case is what we have seen for the last several years, a couple of percent using x8/x8 vs x16/x16. Modeling apps and micro benchmarks are a different case, of course.there is no difference NOW..
This is not like getting stuck with x16/x4. That has and still does makes a huge difference, especially on nvidia cards.
There are a lot of variables. Generally no, the same data is sent if the same game quality settings are used in 1024x768, 1920x1200 or 2560x1600.Does required PCIe bandwidth increase as resolution increases, like how higher resolutions need more frame buffer? Or does it not matter?
