Some opinions regarding new build
Kaze105
I finally decided to build a new desktop that can handle a lot more than my laptop.
I will be using for gaming, programming, video editing, and a few other things.
2000-4000, yes.
3) Where do you live?
Ohio
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything except monitor.
None.
6) Will you be overclocking?
Yes
I will receive this monitor in a week as a gift.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
Within 1-2 weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Raid and SLI are my main priority.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, will use Vista-64 for now.
Here are some main things i will use. (excludes small things like fans, heatsinks, etc)
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820145224 (for 8GB)
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Video Card x2 (mobo doesnt do 3): GeForce GTX 275 (still deciding)
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Hard drive: Primary - http://www.newegg.com/Product/Product.aspx?Item=N82E16820233087
Extra x3 - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136313
Ive been relying on laptops for quite a long time, so i would like some opinions on what to choose. The price is fairly high, but i dont mind as long as it can last for some time without having to upgrade.
IIRC, a single ATI HD 5870 performs pretty close to GTX 275 SLI while being cheaper, cooler, and significantly less chance of scalabilty issues with games
oh and ditch the dominator RAM. They're never worth it. There should be cheaper 6GB sets of RAM out there
Posted via [H] Mobile Device
There are cheaper DDR3 1600 kits that are available. Get the G.Skill or Mushkin CL9 kit... each runs at around 1.5V-1.6V, whereas the Corsair Dominators run at the Intel Core i7 limit of 1.65V.
You want DDR3-1600, for OC'ing. ;)
Yes, the HD5870 is worth it since NVIDIA's next gen stuff won't be out until next year.
I didn't check your other parts since you didn't list the part names.
Ah thanks for ram, didnt see it was 1333 haha.
as for list:
Case: Antec Twelve Hundred
MoBo: ASUS P6T Deluxe V2 LGA 1366 Intel X58
PS: CORSAIR CMPSU-750HX 750W
CPU: Intel Core i7 920 Nehalem 2.66GHz
Prim HD: Corsair P128 (CMFSSD-128GBG2D) 2.5" 128GB SATA II MLC Internal Solid state disk
Extra HD: Western Digital RE3 WD1002FBYS 1TB 7200 RPM 32MB Cache x3
yeah ATI's $260 HD5850 outperforms the $350 GTX 285, Nvidia's fastest single gpu card. Since the HD5870 is faster than the HD 5850, yeah the HD 5870 is worth getting over most of the GT 2XX series cards
Looks fine to me. I'd get Caviar Blacks instead of the RE3 drives and just use the TLER tool to adjust for RAID. You are throwing those drives in a RAID array, right?
Yah, the blacks are the same drive, basically with TLER disabled, so you can save a nice chunk of cash there.
Thanks, any suggestions in terms of good fans for the i7 920? (planned water cooling, but decided to go with air).
Thermalright Ultra-120 or Megahalems.
Depends on the game and resolution. There are games where the GTX 285 still outperforms the HD5850.
I wont be playing games requiring extreme graphfics for now, so ill just go with the cheaper one.
Are there any fans for i7 on newegg? seems like ultra-120 is discontinued and megahalems isnt on newegg.
