So was curious if I use this water cooling solution from
https://www.ekfluidgaming.com/ek-fluid-gaming-a240r
and two of these expansion with it so I can use the two 360 Rads
https://www.ekfluidgaming.com/ek-fg-360-expansion-pack
I will be also purchasing another water block
https://www.ekfluidgaming.com/ek-ac-radeon-vega-inc-fittings
Would this be enough to cool two vega 64 cards and CPU
I also awhile back had purchase this kit from ThermalTake
https://www.thermaltake.com/products-model.aspx?id=C_00002789
and never used the pump.
I was curious if I should use the pump from thermaltake or one come with the EK kit above. I am also getting other parts for the loop. Will this pump work fine with kit above even though it is aluminium?
My next question is should I just use the custom configuration and get the parts they recommend that are cooper base?
Here are the parts they recommend
