Going to redo my last post because I didn't format it well:
I like to play current games, surf and do some spreadsheet work and a program called Trade Navigator that runs lots and lots of math formulas
Trying to stay in 300-400 range
3) Where do you live?
Phx, AZ
CPU/MB
6) Will you be overclocking?
Yes but I don't do it intensively
BenQ 1920x1200 as the primary. I plan on getting a 120hz screen in the near future.
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Going to have a single GTX470 for gaming and keep the existing 9800GTX for extra monitors and perhaps a PhysX card. SLI might be in the future.
Yes, W7 Home Premium x64
I'm not in a hurry but am ready to buy now. I get the impression from reading the forums that Intel is still pretty much king of the CPU heap but I'll go with whatever the best bang:buck ratio. I usually keep a system for 2-3 years before major upgrades or rebuilds. I'll also probably start playing with water cooling with this build too.
Thanks for any advice.
Phx, AZ
CPU/MB
Now
