Is anyone here familiar with the concept of a solid state crocooler? It's an extreme low-temperature device typically run from liquid nitrogen/helium. They operate on different principles from what I can tell. Some are designed as stirling engines, the more recent are pulse tube crocoolers, which have even fewer moving parts.I'm not too familiar with the theory, but I've seen them advertised at temperatures of around 1.4K (-457.15ºF/-271.75ºC). They're big, bulky, probably cost a small fortune, and have that nasty issue of needing a constant supply of volatile cryogenic liquid, but past that, it seems to me it would push the idea of extreme cooling into overkill. Better yet, most of them that I've seen appear to focus the temperature on a single component called a Coldtip Thermal Interface. Aside from the chipset probably shattering from the cold, what's the consensus on these?
Some links:
http://www.janis.com/p-ssptc.html
http://www.eng.ox.ac.uk/cryogenics/
http://www2.jpl.nasa.gov/adv_tech/coolers/summary.htm
Some links:
