xhx said:Cool. Looks just like AC's Aquatube+Aquabay.
TehRoflcopter said:Yeah, but you want to know the funny part? He probably paid a fraction of the price and didn't wait 3 months for it to come in =).
kleox64 said:Damn right, also he didnt stop production or give up after the milling tool broke (aka the aquacomputer copper aquatube)
EnJoY120 said:TopNurse: The top port will obviously be the intake, therefore water level is irrelevant.
Yes this is correct. Eheim 1048 flows eh? Hmm, I could be SOL, my pump has a 10M head LMFAO.Top Nurse said:The top port will be probably used to fill and bleed the system. The bottom back port should be the intake (to the pump) and the upper back port should be the return line. And yes there are known problems with Aquatubes in horizontal placement when you run the flow up. Usually happens when you hit about Eheim 1048 flows.
kleox64 said:Out in the wild? I havent seen any unless it's available to purchase then in my books it doesnt exist, Ive had enough of manufacturers doing paper/press releases with no goods available (the copper aquatube being of them).
Top Nurse said:Most of them ended up in Japan IIRC. So I gather you think IBM XT's don't exist because they aren't for sale?
kleox64 said:They dont exist IMO, a product has to be available to purchase not just some paper release. ATI's X1800 is another example.
Yeah exactly, I tried as well. Although I love the brass, my first choice would be to have the res made of delrin.kleox64 said:Anyone want to find me a copper aquatube that I can buy right now?
I thought not.
nikhsub1 said:Yeah exactly, I tried as well. Although I love the brass, my first choice would be to have the res made of delrin.
I thought not.
Top Nurse said:The guy that made this one would probably make you one and thus it is available for immediate sale.Might take a while for delivery though.
a agree with you on some points, but in all seriousness, if you hand the CAD drawings over to a CNC opperator near you (check the yellow pages) you could have one made.EnJoY120 said:Who made this?
DFI Daishi said:a agree with you on some points, but in all seriousness, if you hand the CAD drawings over to a CNC opperator near you (check the yellow pages) you could have one made.
the cost is the only real issue between you and having one.
i can walk into a particular machinist that i know in town, and if i have a reference piece or a cad drawing, he will have the part to me within the week. he will make it in C110 copper, brass, aluminium, or common grades of steel, if i ask for it. the only issue is that shop time cost real money. my custom cold plate cost me pretty dearly as a result, simply because one-off pieces are expensive to produce.
he isn't a friend at all: i checked the yellow pages, called around, and then payed him a visit. i didn't know him before then.Erasmus354 said:Not to mention that unless you have a friend like you do, most machining places will sit there and laugh at you if you ask them for a one off part.
Yeah, I did my leak testing with a D4, massive bubbles. However, If i put a barb in the top port with a piece of tubing like a tee line, things went well. Last night I took it apart and polished it, while I was at it i stuck a barb in the CENTER hole on the inside sorta like the aquajet? So the inlet has 2 barbs. I think what I will need to do is keep the top barb and piece of hose and use a fillport connected to the res.R1ckCa1n said:That is very purdy! I am interested to see if you experience unstoppable bubbles like all other 1/2" users.
Linky to foam?R1ckCa1n said:Nice work Nik. Black on Copper looks very sweet.
Maybe a piece of foam like Thermochill uses for their res would work for you?
nikhsub1 said:I thought about putting a plastic clown fish in there, lol.
