Moogle Stiltzkin
- Nov 11, 2004
I just bought a X-rite Eye One Display 2 calibrator that has the Eye Match software bundled with it.
It's good and easy to use but the final result page graph does not show where it stands in regards to SRGB Adobe RGB etc.
Also no DE score :X
I heard the NEC Spectra View II calibrator software was very good. But when I tried to install Spectra View II software, i found out it does not support monitors that are not NEC.....
So the software i am looking at now is the Basiccolor Display version 4.1.8
Is the later better then the Eye Match software ?
Also no DE score :X
