softmodding to x800 xt-pe sites
turmania
can someone give me someuseful sites where i can step by step softmod x800pro vivo into x800 xt-pe specs? it will be very usefull. thanks.
I have a question. If something goes wrong during flashing the BIOS, is the card rendered useless like motherboards or is it somehow redeemable?
You should be able to pop in a pci video card and then reflash back to a good bios. If you don't have a pci card you would need to remember the exact keystrokes to flash the card blind.
If you could go into more explanation or possibly point me in the direction of a place besides google that could help me. My internet isn't running that fast right now. *EDIT* I don't have a PCI card and I find no reason in buying one.
