Socket M or Socket 478
nitefallz
I'm confusing myself. I have an Intel T2400 Core Duo processor which I believe is considered Socket M. I pulled it from my Inspirion and replaced it with a T7400 which is a C2D processor. I see that the T7400 is Socket 478 or Socket M sometimes. Which is correct?
I want to use the old T2400 in a new HTPC I'm building and I'm trying to find the right motherboard but I'm not sure which socket type I should look for. I think 478 might be suitable, but I'm not 100% positive.
Any help?
I'd just be careful because s478 boards won't be what you're looking for. You'd be looking for s479...and probably socket M instead of s479 for Core 2 support. That's off the top of my head without looking up anything though.
You need to look for a HTPC board with Socket M support. Socket 478 was the older Pentium 4 socket pre-LGA775.
Thanks for the info. Any recommendations?
/edit
Seems like the Abit IL-90MV would work. Additionally I found someone online claiming to be running one with the same CPU I have.
