Socket A help
RemoW
Hi all,
I have a barton 2500+ running on an msi kt4 mb (6712). I recently purchased a 250gb hd which my system only sees as a 128. Yes, I could buy a promise card, etc. But I see this as a good oppertunity to upgrade my mb. :)
I have the system OC to 2900 + levels and could do better if I had better memory (samsung 256 pc2700)
What current mb is the fastest, will oc, support natively my 250gb hd. I want sound, lan, and usb2.0 and all for less then $80. Is this doable. Someone recomended a soltek 75frn. I would prefer to avoid jumpers. Yes, I need a socket A mb.
I did check new bios for my MSI but none of the updates list improving the size of the hds.
Thx,
Dan...
Thx for the quick reply but my bios still doesn't support the 48 bit lba.
Any suggestions for a good mb?
Dan...
Dan...
Most motherboards with NForce2 Ultra 400's are pretty nice.
i like both the Abit NF7 they make several of these or the ASUS A7N
I had an DFI NForce2 Ultra Infinity. Same as the Lanparty but without all the UV reactive coloring and extras. Good board.
For $80 go for some kind of Nforce 2 Ultra 400. Try to get it with the MCP-T southbridge.
