Socket 939 Upgrade Predicament
nthexwn
So...
I woke up this morning and discovered that my motherboard is dead. (Edit: it's alive, but it's on it's deathbed and I'm still wondering if I can fix it) It won't even attempt to POST. The motherboard (MSI K8N Diamond Plus) also has an expired warranty/RMA period.
This sucks because I only have that one computer (I'm posting this from a public library) and don't currently have the cash to pay for a replacement motherboard. This leaves me with two options:
*Wait until my next paycheck so I can afford a new one (Not happening. My computer is an essential part of my life. I come home from work every day and playing games keeps me from giving up on life and killing myself. I'm sure some of you can sympathize.)
or
*Use Newegg's financing to buy a new motherboard and pay for it later
The problem is that Newegg no longer carries my motherboard and the ones that they have in stock don't appear to be all that great:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010200022+1070907495&name=939
Can anybody recommend which one of these to pick up? I'm considering using this as an opportunity to switch over to an Intel based system, but I've already got two gigs of DDR500 as well as an Athlon 64 FX-60, so I'm pretty set on getting a replacement socket 939 board. Another problem is that I need to buy over $500 of stuff to get the financing. I'm thinking I'll use this as a chance to finally upgrade to Vista, but that still leaves a gap of around $100-$200 of stuff that I don't need in order to fill in the gap. Given my existing setup that I mentioned earlier, would it actually be possible to get an Intel board, CPU, and DDR2/3 platform that out-performs it for less than $500? (I'd exclude Vista if I had to)
I'd like to get this taken care of A.S.A.P. so any advice would be appreciated! I'll probably be able to check back here after I get off of work tomorrow.
Thanks,
Alex
check other than newegg
msi will also prolly fix the board for about 25$ you should also make sure it is the mobo not ram, video or processor
Okay so as an addendum, here's another question:
What is "THE" LGA775 motherboard to have right now for Core 2 Duo/Quad systems? I'm hearing good things about the Asus Strike Extreme, but I haven't kept up with the hardware news lately and don't really have time to do any research at the moment (only allowed 1 hour of web time a day at the library...)
I usually don't like skimping on the mobo. The prices on them are close enough together that I'd rather have the best with all the features, stability, support, etc. for what usually ends up just being a little extra.
Well when I got home it decided to come back to life!
To elaborate further, in the last few months I've had an intermittent problem with the computer not booting. The motherboard came with a dongle that has lights in place of motherboard beep codes. The lights will sometimes get stuck on "initializing keyboard controller". Every once in a while I'll also get a CMOS checksum bad message during boot. At times it can't find the HDD. These symptoms have become more frequent, to the point where I usually have to boot once or twice before it even gets as far as loading Windows. Once I'm in Windows, everything functions just fine. I can play games all day (and you know I do!) without problems and life is good. These issues only occur during boot.
In my few years of computer experience, I'd say it's safe to blame these symptoms on the motherboard. I'm thought it was completely dead, and I'm actually afraid to reboot now for fear that it will be!
To be safe, I'm still planning on replacing this thing just in case, and will try to leave it on for as long as possible. I'm still looking for replacement/upgrade advice, but can at least respond to any help, or do some research on my own for the time being.
have you taken a peak at the mobo itself? I'd check for leaking/swollen or exploding capacitors. they are known to cause such issues
I just spent a few minutes checking out the capacitors and didn't find anything wrong with them.
I'd find another s939 board on the FS/FT forum. There's a few people selling new or nearly new Ultra-D's.
Here are some choices from TD:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1569&
Here are some choices from the egg:
http://www.newegg.com/Product/Produ...deValue=719:28866&PropertyCodeValue=719:18489
if you'd rather upgrade to an Intel setup, what features do you need in a motherboard? The crowd favorite right now is the Abit IP35 Pro if you don't need SLI. Other alternatives are the IP35/IP35-E, Asus P5K-E/P5K, and Gigabyte GA-P35-DS4/P35-DS3R/P35-DS3L. If you need SLI, the eVGA NF68-A1 is actually the best board to get.
For the CPU, go for an E6750 or Q6600.
If you want 4GB of RAM, get Vista 64bit and go with a 2x2GB config. If you only need 2GB, go for the G.Skill 2GBNQ kit if you go with a Q6600. If you need 2GB and go with the E6750, get the Crucial Ballistix DDR2-800 instead.
For cooling, go with a Scythe Ninja Plus Rev.B, Tuniq Tower 120, Ultima90 + hydrowave fan, or Ultra 120 eXtreme + S-Flex fan.
$276 - Core2Quad Q6600 G0
$125 - Abit IP35 ($25MIR)
$112 - Vista 64-bit Home Premium OEM
$66 - 2GB G.Skill NQ kit
$55 - Ultima 90 + hydrowave fan
$635 - $25 MIR
You could also sell your old parts to help offset the cost of the new ones.
i had the same preoblem (except i just wanted to upgrade)
i found i could get an M2N-MX SE board, 2gb ddr667 and a 4000+ CPU for $275
Your problem could be due to
1. the power supply is able to die. What is the watts on your power supply and how long have you been using it? If you have many perpherials hooking up, that could explain it needs some time to warm up. Once your computer has warmed up (electricity flows have been stabled), like once in the windows xp, everything is fine. That means just leave your computer on 24/7 then you won't have to deal with the problem.
2. If you have many softwares installed in your windows XP and having been using your computer for while, it is best to let all the background drivers installed completely before you hit the continue button in the log in page. Make sure the drive light stop blinking before continuing. Like my system in sig, if I hit continue in the log in page of Windows XP while the drive light is still active (loading drivers), most of time I will get a blue screen of death saying a driver equal to zero message.
So your entire problem might not be due to the motherboard.
I'll second that emotion! If I were you, I'd be trying a new, quality, power supply. ;)
Thanks a ton Engi, I'll keep those recommendations in mind!
It's a SilverStone ST75ZF
It's a 750w PSU with 72 amps split across 4 12v rails. I've had it for less than a year. I suppose it could be dying, but I kinda doubt it.
Nice piece! It's definately got the power and reputation, but I'd still check it out. Stranger things have happened in ComputerLand. ;)
Well this is very strange...
The computer is getting harder and harder to boot up, but still functions perfectly fine once it's booted.
Every time I boot up it will lock on "initializing keyboard controller" and I have to hold down the reboot switch for a few seconds. After it reboots it will usually make it past the keyboard controller error, but never seems to work directly without use of the reset switch. I thought maybe the pin-outs for the power/reset switches on the front panel had come loose so I checked those, but everything appears to be in working order. I even tested the pins directly by using a screwdriver to make the contacts and came up with the same results as I did by using the buttons.
Lately I've had to use the reset button about 10-20 times per boot before the computer finally POSTs and starts loading the OS.
I really have no idea what's causing this, and still think it's a defective motherboard. It's still working right now, so I don't want to have to replace it just yet, but everytime I have to shut down or reboot I'm afraid it won't come alive again.
I think I should probably replace the battery on the motherboard to see if that solves anything, but I honestly don't even know where to look for one. Would a regular drug store such as Wallgreens or Rite-Aid carry them?
Is there anything else I should try that could prove to be a quick fix?
I like my system just fine as it is and really don't want to upgrade/replace and end up re-installing my OS and re-tweaking everything, but at this rate my computer might not even turn on tomorrow... :-/
Thanks again,
Alex
you should be able to get that battery there, if not, try radio shack, a camera store, best buy, kmart, etc, etc. there is a chance it could be the psu. just because you have a good psu, does not mean that you cannot have a broken, good, psu. try swapping it out. and make sure all power connections to mainboard are made. check the connectors for any sign of melting or charring.
there is prob a bunch of s939 stuff on the for sale forums. i have an ultra-d, evga nf41, dfi rs482 infinty, foxconn 6150 board, coolers, x2 3800, 4000 sandy, etc, etc.
my old a8nsli deluxe did that too; wont boot, and wont display. once in about 100 or so resets, it'll work. unfortunately, i changed the battery and still no success. i never solved the issue, so i just sent it to RMA.
just leave the computer on until your new board arrives.
or get a
e4500 (100) and use the stock cooler. i got a geminii for $15, and i'm sure they're having more rebate/promotions going on right now too
ip35 (~100 AR) or ip35-e (~90) or the foxconn 935a, it's around $70 + shipping + AMIR.
2GB memory, ~$50 or maybe even $40 AR
so that'll run you about $250-300.
check w/ hotdeals here or slickdeals
