newegg.com said:Compatibility: Up to Athlon64 FX 3200+ (socket 939/940)/Athlon64 3200+ (socket 754) and above; Pentium-4 socket 478 3.2 GHz and above
Yep that if you can fit it. You could also use it little brother, the XP-90 if the 120 doesn't fit.darktiger said:I say XP-120 if your mb can support it....
