Socket 775-- Upgrade from P4 to Core2Duo?
atto
I have a P4 2.8Ghz, and it serves me well, but it runs pretty hot. Can I upgrade to a Socket 775 Core2Duo, and is it worth it? Or should I just wait until I can afford a newer (from the ground up, so to speak) system?
Go get yourself a core2duo (reuse your heatsink/fan and get an oem cpu). It's a whole lot cheaper than a new computer system and you'll get a huge boost in performance. The P4 was a serious stumble for Intel.
I should have mentioned this earlier but I have a no-name Intel motherboard (I have a Sony Vaio RB44G)... According to CPU Z it's the D915GRO.
Would it support dual core processors? I have read some posts on other forums saying it's too old but I'd like to get another opinion.
Yeah, you will need a new motherboard, probably new ram as well. Likely a new video card if you are on agp still. If you are willing to buy used, you'll find some great deals when sandy bridge is released on January 5 when a lot of us make new builds
As I thought. And no, the graphics are on PCIe... it's not that old!
I'll be saving up for parts then.
If you are at the point where you need to replace CPU, motherboard and ram then unless you are planning to build a bottom of the range system (the core 2 based celerons are actually a pretty good deal) you are probablly better off skipping over core 2 and going to i series stuff.
Pentium D is terrible, might as well keep his p4.
OP look in hot deals, you can get a Athlon II 210e @ 2.6GHZ for $36 shipped and it's about as fast or faster than a c2d.
Why is it so cheap? Is there a premium for Intel processors?
The reason I ask is because despite being stuck with this P4, I've been really satisfied. My last AMD was painful so I'd like to stay with Intel.
