Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Ok here we go, either the ASUS P4P800 SE, with a Intel P4 3.0C Northwood for: $292.99. Or ASUS P5P800, and a Intel LGA 775 P4 530J 3.0 Ghz prescott for 281.99? Thanks
I have the 3.0E with the P4P800 SE but I would definately recommend going with a LGA775 chip and mobo. Granted that, I don't think the P5P board is so hot because it lacks PCIe (and thus future upgradability) and also uses the same chipset (865PE) as socket 478 boards.
Unfortunately, I don't know enough about the 9xx Intel chipset performance to make any recommendations outright, but I can tell you that I'm running a similar system as you plan to get for 478 (without the Northwood), and it isn't bad, but it isn't futureproof as far as getting an LGA775/PCIe system is.
If I would get PCI-E board this looks like it would be it, plus it is a combo, so save $30 bucks, ends up even cheaper than the other two i said above.
EDIT: nevermind, this processor is the 630, which is 260 bucks.
