so which m/b and is it true?
umcpgrad
I got my heart set on 757 pin m/b -> cheaper.. but i found .. it doesn't have dual channel support for memory.. is that true?
and also should I go for soltek or lanboy or msi or asus??
Yes, it is true, 754 is single channel only. From what I've read though, dual channel memory will only give you a 2-3% performance boost which most people would say is negligible, so if you have your heart set on 754, then go for it and don't worry about the whole dual channel vs. single channel thing.
As for which mobo, I've been looking at 754 also lately and have been looking at EPOX, DFI, and Chaintech boards because I've heard the NF3 boards overclock really well and I would like something to tinker with. If you're going that route though, I've also heard that they have problems with dual sided RAM chips (This I haven't confirmed though so don't take my word on it)
which n3 m/b u getting?
there are n3 ultra, n3 250gb
and n3 250
and n3 150...........
I was looking at the n3 250gb soltek and lanboy...
It depends on how many DS RAM chips you have ;). You can only have 2 sticks of DS RAM. If you put in more than that, you will start getting strange memory errors even at stock speeds. It is a limitation of the on-die memory controller in s754.
So then my two sticks of 1 GB PQI ram should work as long as I don't put in say a third stick? That's great to hear.
Yes they will work.
The problem you're hearing about is 4x Double Sided sticks either not working or only working with 2T..
dfi is also about 30 dollars more than anything 250gb wise.. btw the lanboy is the 250 version.. what is the differences of ultra, 250g, 250, 125 n3s ??
I have a couple of friends that use 1.5 gigs of ram on their S754 at 2.5T and haven't had any problems
