If they can do anything about the cache latency and thrashing things might look up. AMD's next thing on Win 8, might do better too.
I'm not going to buy one, and some are buying cheap ones just to OC them.
One of your charts shows a 10% difference in favour of win.8. That's actually quite a BIG difference. Reference different charts next time.
It's actually... Not.
40 vs 44fps
60 vs 66fps
100 vs 110fps
40 vs 44fps
60 vs 66fps
100 vs 110fps
There are quite a few benchmarks around right now for the FX processors. But even among those more variation than I would have expected. Not defending FX now because it's not what we wanted not even near it...but that is interesting anyway.
I would expect prices to fall pretty quickly I can't see why you'd pay £200+ for the 8 core FX when the i5 2500k is cheaper than that. If they pull prices down in line with that and drop the 6 and 4 cores down cash wise it might escape a thumping on many sites.
Yes performance is a problem, but the biggest problem is price v performance AMD are dreaming with these prices.
bulldozer has been tested on windows 8 and its not much better.
Zarathustra[H];1037899586 said:What does this mean for BD? Well, seeing that SB isnt optimized, neither - probably - is BD. This means that BD will likely benefit even more than it does in these charts in the final version.
I'm guessing by as much as 15% in WOW, and probably by as much as 6% in solidworks.
From a OS standpoint, this difference is nothing to shrug at. It' won't suddenly make BD faster in single threaded operations, but it will narrow the gap a little bit.
world of Warcraft: Cataclysm 2560x1600 no AA
Win. 8 - 80fps
Win. 7 - 71.50fps
My maths makes that more than 10% difference.
Not sticking up for Bulldozer, not saying anything other than 10% is a rather a big difference to be called 'not much better'. MrBigshot should have picked some different charts.
I don't think 10% is a big difference at all personally.
40 vs 44fps
60 vs 66fps
100 vs 110fps
Well fx 8 core is close to the i5-2500k in some cases better but it's too mixed to really be conclusive.
Trouble is it costs more than the Intel chip so where's the deal here?
Forget about overclocking the performance is rubbish on the FX range you'll suck a load more power for not that much gain all the benchmarks show the same thing. The 2500 overclocks great.
This has the price of a top end processor without the performance. The design of the FX CPU is simply crap, it's flawed to hell. It's a P4 gone wrong ooops lets ramp up the clock speed to help. It didn't convince back then, it sure doesn't right now.
The 6 core is slower than the 6 core PhII the 8 core isn't even all that in some cases. It's a lousy upgrade for 4 core AMD users.
10% is huge, your smoking something.
A few benching results with cpu on subzero cooling
BD is a lot of fun, it will take you as high (Mhz) as your cpu cooling can (hold the heat load)![]()
10% not a big difference? from a scheduler tweak?? that's a huge difference!
That's right... 10% is not a big difference. You can keep asking the same question and I'll keep giving you the same answer. It doesn't matter how you try and sugar coat it. 10% regardless of where they got it "from" is still 10%
It would be one thing if it got the gains it did in WoW across the board but it didn't so yes, again, not a big difference. When it can do this across multiple different tasks and not a one off example, then get excited.
You say 10% isn't a big deal but less then 10% is the difference between BD and i5/i7 at stock clocks in most games with a few really cpu intensive games be the exemption like sc2 and WoW. So yes "IF" we saw a 10% increase in performance across the board in games that would be a pretty big increase. Of course there is only 3 benches there and those 3 benches could easilly be nothing like how the rest would turn out but yes 10% could be pretty nice.
Windows 8 does not exist and windows 7 does. Highly threaded apps that it does well in are few. This "10% increase" a few people are so happy about is not only small, but meaningless. By the time it's a reality with Windows 8 both Sandy Bridge and BD will be old and irrelevant.
Noticed you have your CPU overclocked, if 10% is meaningless mind telling me why you are trying to gain a few percent performance gains when it's "meaningless"?This "10% increase" a few people are so happy about is not only small, but meaningless.
Windows 8 actually does exist. It's likely to be released sometime in 2012, hardly talking about years away. Not to mention SB and BD will hardly be old and irrelevant.
Actually it's not the truth, it's your opinion. Hardly see how you can predict the next few years and what is going to be multithreaded. Hell games coming out now are getting better at using multiple threads.
I guess I'm just not as impressed as you are by a processor that is so awesome and advanced that it performs like shit.
It doesn't perform like shit, what it does is that it doesn't live up to expected performance.
They need to focus on L1 cache speed
Too many things went wrong. I think BD could be the next big thing, but it would require enough early adopters to show developers that coding for a seemingly infinite number of cores would be worth the trouble.
I honestly do blame the software developers to some extent. With a program where performance really matters, why would it be single-threaded in this day and age? How many generations of multi-core CPUs does it take for these developers to start using them properly? Windows scheduler wasn't built with BD in mind, but how difficult would it be to make an update for it? Right now, BD's tech with current software is like running a SSD on an ATA100 cable...
NSide -
I'm a software developer for a leading manufacturer of Computer Automated Engineering software. Think Finite Element Analysis, Computational Fluid Dynamics, Thermodynamics, Aerospace, etc.
Not every problem can be written to run on multiple threads. It's not like we can just go in, flip a few compiler switches, and, "Blamo!", our code is multi threaded and scales to N number of cores. Some problems scale, some do not. Some problems are limited by memory bandwidth or disk I/O more than by the ability of the CPU to crunch the numbers. Some are GPU limited.
I suspect the same applies to the games you want to play and see scale perfectly on your BD, i7-980, or whatever.
You're right, I shouldn't have said truth, reality is much more accurate.
So 2012 is when BD is going to own eh? Ok, we'll see about that.
\NSide -
