Is it the architecture?
the shared cache?
the longer pipeline?
the manufacturing process?
the shared FP?
all of the above?
I see nothing wrong with BD.. infact I believe is about the best piece of tech that comes along, AMD has a champ here, but trolls can't gasp why is NOT killing SB.. just give this tech a time and you will see how it will perform... more cores is they future...
AMD HAS A CHAMP? DUDE! Lay off the brown acid! How deluded can a mammal be? Geezus!
BD SUCKS. END OF STORY.![]()
Did you even read any reviews.
I honestly have no idea what happened. Double the transistors, bigger die, more cache, cores, and this still did not beat the 2600K. Even the 1100T kept its ground against it in many areas and went past it in others. Just epic fail. I am sure someone like Anand will do a write up about what happened.
AMD Modules are the Way of the Future, Intel FanBoys can't see this, heck I believe in the future we will have 3 cores sharing a mudule, why? the future is Highly paralel codes, apps, games..
but TROLLS... will be TROLLS... so I can't help you guys see the future, I for one I'm waiting on Interlagos...
Wrong.. its actually less expencive to produceMore expensive to manufacture.
I'm serious about the question. On paper nothing seems to be wrong with BD, but it looks like the opposite of what it should be. Slower, more power hungry and less efficient.
If they would have been more conservative and used a more traditional architecture they would have gotten away with fewer transistors for the same performance which would have been dramatically cheaper.
Of course I'm not personally interested in this segment since I don't like leaf blower systems anymore.
I am sure AMD saw that option too... but they new they could only compete with intel, what AMD did with BD is to create a new tech so radical and so new that NOBODY will dare to compete with it, why..?
in a few years there will be 20 core desktop CPU with 4 cores sharing a BD Module.. that makes things so cheap for AMD, all the software guys needs to do is wright apps for it.. how is Intel going to compete with 20 cores without charging $10k for one I can't see how they could do that with OLD CPU Tech..
the shared cache?
the shared FP?
all of the above?
Because if it takes 20 cores to do what Intel can do in 1/2 the amount is pretty inefficient if you ask me.
somebody had to do it, if intel could not, AMD had to, I mean Apple Hardware is dead, as dead as the RISC cpu is, but I bet if it was Apple doing it, nobody would be bitching about it...That's fine and dandy (good to be the leader in technology and pave ahead),
Yes, so the real question is, how many modules can they stuff into a single package? Could AMD put 16 cores into a single package? I would think so, and the performance would be very compelling, especially for the cost, at least in the IT space.
in todays software state? Yes.. but the future will be more simple cores each working in highly parallelized coded apps, just like relentless ants..
Model Cores Frequency TDP Pre-order price
Opteron 6204 4 3.3 GHz 115 Watt $516.13
Opteron 6212 8 2.8 GHz 115 Watt $303.17
Opteron 6220 8 3.0 GHz 115 Watt $588.93
Opteron 6234 12 2.3 GHz 115 Watt $430.00
Opteron 6238 12 2.5 GHz 115 Watt $516.13
Opteron 6262 HE 16 1.6 GHz 85 Watt $588.93
Opteron 6272 16 2.1 GHz 115 Watt $588.93
Opteron 6274 16 2.2 GHz 115 Watt $720.17
Opteron 6276 16 2.3 GHz 115 Watt $881.22
Opteron 6282 SE 16 2.6 GHz 140 Watt $1135.26
ThiI guess we'll just look forward to Piledriver and see if that does any better, because I simply don't see BD making much of a difference at the current time.
RISC design strategy is alive and well.
Just ask anyone with a smart phone. Which is exactly why Apple plans to jump on it and Microsoft has Windows 8 with ARM support out of the gate. ARM is a RISC based ISA.
It's a combination of issues.
- GloFo hasn't perfected their new process yet I don't think, Llano having problems I hear through the grapevine.
- The design is odd and a departure from anything we've seen in this particular market, except maybe Intel with their Netburst. The modules on Bulldozer have a monolithic design philosophy where each module is sharing 2MB L2 Cache.
- Throughput advantage, a slim one at that, cannot be claimed with how W7 OS Task Scheduler assigns processes and threads to cores (haphazardly), it is beneficial if two related processes/threads/forks/children occupy the same module and share the same L2 because Bulldozer allows dynamic resource allocation between threads.
- Some sort of unknown tying up of resources/thrashing seems to be occurring.
- The thread retire logic, prediction prefetch, unified scheduler, or thread retire stuff seems to have given up some IPC.
- This processor isn't meant for the desktop by nature. Most applications are still very heavily dependent upon single threaded performance, something eight cores or sixty-four cores won't really do to help solve the problem because sometimes in computing it is very difficult to make a problem vectorized or to make it parallel. More cores = not helping.
- Performance of BD is erratic at best. Why did it do well in the second pass of the x264 encode when it was being hammered but when it comes to certain tasks it chokes and Thuban and Deneb actually sometimes tie or beat it in the metrics?
- Longer pipeline and complexity in having to juggle a lot of complicated stuff.
- I think everyone suspects that circuit power gating isn't working the way it ought to.
The design while brave and a walk in the right direction, is very short sighted. I believe the frame of mind was "We can combine common functionality/sharing functionality between two cores and minimize silicon area to increase die real estate so they can go and put more cores on a die.
That's fine and dandy (good to be the leader in technology and pave ahead), but something is seriously messed up with single threaded performance and even multithreaded performance.
The only thing can hope for is between fixing whatever issues there are with Bulldozer, production, design, or otherwise, they have the kindness to just go ahead and shrink Thuban to a 32nm process in the meantime.
