But why?Even if the combo makes a decent chip, I will be sticking with dGPU option.
But why?
AMD APUs are pretty much junk. Not ALL that much faster than iris pro. I don't see the big deal here at all. It's gonna be slow
If it's 1050ti+ levels of performance then it might be something.
So if I was in the market for a gaming laptop I would go all out for anything with Nvidia Max-Q, if guesses/tech specs are correct this supposed joint venture chip cannot compete.
If I was going for something to replace my Surface that is Surface like then I could see myself selecting this option if it was available.
Take a look at the Xbox One X to see what AMD can do with their APU's if they wanted. 980Ti level GPU with access to more VRAM than a 980Ti
GTX980TI performance? The Xbox One X is around a RX480/RX580 card. And last time I checked it was nowhere near GTX980TI performance. Did you mean GTX980 non TI?
And more VRAM is a maybe, it depends on the distribution for the game. Xbox One X games will use around 6-8GB for the graphics part I guess. Remember even today ~3GB goes to the OS etc and isn't even available for game application or graphics. So 12GB is already 9GB in that regard before you even begin. And then you can remove what's used for the actual game application next before you get to the graphics part.
And all that with 28nm vs 16nm and still using a lot of power. The only question for future consoles is if they will be ARM or Atom powered and using Nvidia or by a long shot Intel dGPUs.
Had the Xbox One X used a GTX1060 type GPU with the same performance you could remove 75-100W power usage and start with a "Slim" model.
TF isn't a great metric to compare different vendors. Like a Fury X is 8.6 TF but does about the same as a 980ti. That's held true for a few gens now.No, I meant 980Ti. Both are right around 6 Teraflop GPU's
Find the 4TF nVidia card and it's closer to the console.
It’s good indication of The computing power of the actual GPU is, it may ir may not directly translate to in game performance but it’s a valid comparison for raw processing power. For an integrated solution, it’s a beast. Imagine how many people wouldn’t even bother with a video card? Hopefully enough that nvidia’s stratospheric priding falls a bit closer to earth.
