So many problems.. Vista graphics card issues?
aadosx
Hey guys,
I have a Dell XPS refurb that I bought less than a week ago and it's giving me many problems. Obviously Dell tech support blows (even the "special" XPS unit) so they can't really help me. I am close to sending it back, but the only thing stopping me is that I got such a good price. It was a scratch and dent (wonder if thats why I'm having so many issues), but the only scratch on the case is tiny and un-noticable. Browsing through the inventory now in the outlet, I'd have to spend 100 dollars more, and I'd get way less of a system.
Anyways, I wonder if it's the actual computer that's messed up, or if these are just things I can't get around because they're bugs due to vista or sli, or a combination of both?
I bought the computer and it came with Vista Premium 32 bit on it. There was a 320 gig 7200 rpm and a 250 gig 7200 rpm hd in it. The OS was installed on the 320, along with another small 50 mb partition labeled EISA which is actually just some diagnostic Dell tools which I found I didn't need. I also bought an 80 gig WD Raptor for the computer, as the main drive. So I reformatted everything, and hooked my raptor up as drive 0, and the 320 gb as drive 1, and ditched the 250 gb hd. I installed Vista on the raptor, and have my music and videos on the other hd. I also use the raptor for all my programs like games, etc.
So anyways, the problems I've been having...
As soon as I installed Vista I had the first problem. Of course I had no real video drivesr installed yet so the cards weren't using SLI, and one of them was tagged in Device manager. That day I went to work and left the PC on... when I came home, my computer was still on, but the monitor was stuck in power save mode. I called dell and they had me do the random bs. Of course the monitor was fine, they even had me uninstall and reinstall the physical cards, as well as try different ports on them. Finally, completely randomly, the computer some how came on (I believe it was after I took out and reinstalled the cards). They instructed me to update video drivers and attributed the problem to that. So, I went to nVidia's site and updated my video drivers. The computer has 2 nVidia 8600 GTS cards in it. I got the main version of the driver *not the beta* and installed it. As soon as that was installed, I was still getting errors. The computer still at times didn't want to return from sleep. On top of that, during gaming, the computer would randomly completely lock up (happens at least 2 times a night) and I would have to hard reboot it. The "lock up" consists of the screen freezing on the image, a sound clip playing over and over infinitely, and the computer being completely non-responsive. Also, while using anything in windows, at times I would get a black screen for a second and then windows would restore and a bubble would pop up in the system tray saying that there was some problem with video driver "nvlddmkm" and that it had successfully recovered from not responding. This would happen up to every 10 minutes.
So I searched around here a little and on the nVidia website and found a page about updating to the beta while using dx10, vista, and SLI. I now have the beta driver and also two hotfixes from microsoft... all detailed here: http://www.nvidia.com/object/windows_vista_hotfixes.html
Once I installed those everything seemed to run fine... for a while. I am still having a problem while gaming though. The computer will still at times randomly freeze up and I have to turn it off then back on. Nothing works, not ctrl alt delete, nothing.
Here are some screen shots that I once got after having to reboot the PC... these don't always come up though, even if the "windows did not shut down properly, want to choose safe mode?" screen does/
Sorry for the poor resolution! I'm running in 1680x1050 but photobucket is owning me.
http://i133.photobucket.com/albums/q75/aadosx/bluescreen1.jpg
http://i133.photobucket.com/albums/q75/aadosx/bluescreen2.jpg
Edit: I would like to add a few more things. The only other changes I've personally made to the computer are 1) I've added a wireless network card and 2) I enabled overlclocking in the Dell BIOS (but have not OC'd at all), and installed nForce nVidia drivrs for the motherboard stuff and hd controllers, and also installed nTune for oc stuff but like I said, have not even tweaked/messed with it one bit.
Any help is much appreciated, thanks everyone!
-John
- Try using only one card and see what happens. Physically remove that other 8600GTS. Try both cards out and see which one is problem video card.
- Google, download, burn and run Memtest+ on each stick of RAM separately for at least 3 hours or 24 hours max to see if the RAM is causing the problems.
- Turn off Overclocking in the BIOS and see what happens.
- Please list the rest of the specs of your PC and also what did you pay for that system?
Danny,
Thanks for the reply. I believe every spec that matters for my PC is in my sig. I paid 1200 shipped to my door with a 2 year warranty.
I will try what you said. I have also been researching the issue since I posted this thread and have come up with some things I will do tomorrow to see if I can get anywhere. Also, as of now the only game I have installed is WoW, so it's the one giving me the error. It seems, at least for now, the only real error I am having is that it's locking up during game play. Overheating seems to ring a bell but that would be weird considering it's a brand new system.
I am going to install CSS, my only other game, and see if I have probs with that. Other things I'll try:
1) Disable overclocking in BIOS.
2) Uninstall nTune.
3) Uninstall nForce drivers for mobo stuff.
4) Disable Windows Defender (odd, maybe an older fix).
5) Try the driver that's actually downloaded from Dell's website.
6) Move my network card down a slot.
7) Mess with netcard drivers/settings (meh..)
8) Monitor/log temps of processor and gpu's.
9) Check cables and connections inside the computer.
10) Test RAM.
11) Remove network card (well I'd like to try this but it's wireless and if I do, I won't have the internet to play games to test..)
Hopefully I'll get all of that done tomororw, well I'll try things until it works... and I'll let you guys know. Please keep any ideas coming! You would think I'd be more upset to find that these are most likely Vista issues and not hardware (well, I suppose I can't draw that conclusion yet... but there seem to be MANY others with the same problems out there), but I'd actually it rather be that. It doesn't really KILL me to have to restart my PC a few times a night while playing a game, as long as I'm not worried that it's slowly killing my hardware, etc. But yeah, I'd like to keep this PC, so hopefully it's not hardware related, and it will all be fixed soon with new drivers/service packs/hotfixes/updates/etc!
-John
What are the temps of your CPU anyway? Use Speedfan or CoreTemp to find out. Aso, just because it's new doesn't mean that it won't have heat problems.
Oh and you forgot 12): Try using the system with only one card. See if one of the cards is a problem. Physically remove the other video card before going single.
Ok, here's what I've done so far and I'm still having the problem.
1) I changed the BIOS setting to not allow overclocking.
2) Uninstalled nTune, nForce mobo drivers, and even the video driver.
3) Removed one card from the system physically.
4) Reinstalled the nVidia beta driver. I used the beta because I'm pretty sure that the beta driver is what fixes the nvlddmkm problem.. which I'm still not having thankfully.
After doing that I still had the problem. Just now I swapped the card that was in there out for the other... so I'm about to see if it still happens. If so, then I know it's not the cards, right?
Note that the computer can freeze up even when idling a log on screen in the game.. so it's not only during graphics intensive spots.
Oh and also, before I got rid of nTune, I used it to monitor and log temps. GPU1 started at 55C and went up to 68C. GPU2 started at 59 and then was at 72 when the system crashed... so I guess that's not really too hot? I don't know anything about temps. Also the program nTune does (I think) monitor the CPU temps but I guess they don't show up in the log... so I can't tell what they were at when it crashed... but CPU usage was only at 8%... and memory usage at 48%.
Should I try a different monitoring program?
Ok well that time it only took about 5 minutes of listening to windows media player and playing world of warcraft for my computer to lock up. Sigh. So, after it locked up I rebooted into safe mode and uninstalled the nVidia beta drivers. Right now I'm downloading the drivers offered on Dell's website and I'm going to give that a try.
Ok, even with those drivers I'm having the same problem. Also, it seems to lock up much more quickly if I'm also lisetning to music with windows media player while playing the game. I also got a blue screen that time. The "technical info" it offered was a bunch of numbers... which I can post here if needed. It said "the system has enountered an uncorrectable Hardware error.
So now I just updated my onboard sound device drivers, lets give this a shot.
Did you Google, download, burn and run Memtest+ on each stick of RAM separately for at least 3 hours or 24 hours max to see if the RAM is causing the problems?
Ok it is still doing so after updating the sound card error. It took longer, but still happened. I have exactly codes or whatever for whats happening now. I'm about to try that memory test.
So far I've gotten two blue screens today... here are what they said:
The system has encountered an uncorrectable hardware error:
***STOP: 0x00000124 (0x00000000, 0x850BF178, 0xb2000040, 0x00000800)
and also:
***STOP: 0x00000124 (0x00000000, 0x84F9D388, 0xb2000040, 0x00000800)
-John
I just ran a diagnostic on the WD drive I have in my PC that I bought used from this forum. I ran both the quick and long tests and they both said they passed w/out problems... so hopefully that isn't an issue.
Then I called Dell and it turns out they are going to replace my motherboard. Hopefully that will fix things. I am trying to find out exactly what those codes above mean so I'm still working on that.
Right now the memtest program is running on the computer. It says "Memtest86+ v1.70" ... I hope that's the correct version. I did not change any settings, it started running the test as soon as I turned on the PC. There is one odd thing though... it says my Chipset is nForce4 SLI Intel Edition... and as far as I know, I have nForce 590 SLI Intel. Whats up with that?
No idea why the chipset is being read that wrong. But you did get the correct version.
Anyway from a quick google search, that error message seems to turn up when the video cards are the problem. Did you ever just run one card at a time to see which one is the problem card? or have you already done so and both give you problems?
Thanks for the response and thanks a ton for all of them so far.
I have run the computer using only one card at a time, using both cards individually... and had the problem with both. Dell seems to think that the card slot on the board is bad.
I *think* that I ran the test correctly. It cycled through 9 or 10 tests. It then began running the tests again... but I assumed maybe it was just running them on the other stick? Then when it started running the 3rd test I just rebooted.
Here is the version I used. http://www.memtest.org/
Ok I think that simply moving my wireless network card to another PCI slot may have solved the problem... wtf. Still seeing if it will freeze up tho.
Nope... it's still happening. I put my other graphics card back in there so I'm back in SLI. Same business, sigh. I guess I'll just wait for that motherboard to come in and replace it... then hopefully no more probs.
Ok I just ran that memory test all day while I was at work (over 9 hours) and it made 9 "passes" and I had no errors... so I guess it's not that. This is so weird though, last night I was playing a game for hours with no problem. But I'm just waiting for it to happen again. I'm now on the driver from Dell's website. Only once have I seen the nvlddmkm problem.
I would be sending that computer back. Once the 21 days are up you will not have any leverage with Dell. There will always be other good deals at the Dell outlet in the future and now they are selling the XPS720 there.
The only good thing is that maybe they will send you a 680i mobo replacement if you decide to keep this computer.
Those temps are fine.
To see if you have another heat related problem, take the side off your case and blow a housefan into your PC.
If that helps it stop crashing its a heat issue of some form.
you mentioned wireless card...
after installing my new 8800GTS i couldn't even get to the desktop without a machine_check_exception BSOD. could get to safe mode no problems... so i reseated the card, reseated the connectors, checked all other connections etc etc... BSOD... started pulling out other pci cards, well, only pulled one: my linksys wireless card. bam, boots up.
i laughed. uninstalled the garbage software linksys makes you install, reinstalled it, installed the card back into my computer (anyone who owns a linksys wireless card will know what i'm talkin about as far as installation procedure goes) and now it's good to go, hasn't been any further problems with the upgrade.
stupid wireless network card.
Thanks for the tips. But yeah, last night I finally decided that it was all a load of BS and I was tired of dealing with it. The whole experience of getting a new PC was ruined for me (I'm too poor to buy one very often) so I am sending it back... already have it approved. I'll just get another or maybe I'll build (what I was going to do in the first place).
