- Oct 29, 2000
Did it ever go anywhere?
Did it wind up being useable with newer drivers?
Is anyone here using one?
It's dead. Right?
The driver support is still bad and the numbers are still under Crossfire/SLI numbers. They promised much better driver support and performance but so far haven't done either.
With only 1 or 2 mobo's supporting it and a possible third its all but dead at this point.
I think it was really just a timing thing. When the chip was developed, crossfire and sli scaling was pretty poor and the Hydra's promise to go from ~60% to ~85% was very appealing. Unfortunately now that the chip is on the market, Nvidia and ATI have achieved 90%+ scaling on their latest gen of chips. Add in the fact that sli and crossfire are natively supported in drivers and the business case for the Hydra has really evaporated.
No, it doesn't use AFR. What it does is more like SFR, but it can divide the frame around on-screen elements rather than just blindly slicing it in half. There are some pictures of it here.Well, the only really interesting question for me with regards to Hydra is if it also uses the AFR mode, i.e. still features microstutter.
It never went far because of poor scaling with multiple GPUs. The idea itself has so much potential if the efficiency was higher. Even if it only worked for the same graphic cards but let you run more of them in parallel that would be an epic win.
Radeon HD 4870 Quad CrossfireX anyone?
Thanks for the link, looks like it can do several things:No, it doesn't use AFR. What it does is more like SFR, but it can divide the frame around on-screen elements rather than just blindly slicing it in half. There are some pictures of it here.
Yes, it can and will sometimes run standard split frame rendering - this is very efficient for per-pixel processing heavy workloads.
Think about an EVGA SR-2 with Hydra with 7 slots. If Hydra was able to do more than 4 GPUs.. OMG. 7 water cooled GTX 580s in a multi-GPU config. 7680x3200 with 8xSSAA on highest quality settings in Crysis appeal to anyone?
/dream
And a dream it shall be, because even if the Hydra chip supported more than 4 GPUs you'd still be limited to four because of the width of the cards (double slot).
