So look what I just bought
  • Thread starter Deleted member 88227
  • Start date
D
Guest
Been without a good DSLR for about 2 years now, figured it was time to buy another one.
Took it to a friend's Son's t-ball game last weekend. Got a few decent shots.
D
Guest
Used a 70-200mm lens to get the pics and I need to figure out a trick so the fence isn't obstructing the picture so badly. Thinking maybe if I stand back further for the "closer" shots it wont be as apparent in the picture?
IdiotInCharge
NVIDIA SHILL
Use a wider lens, shoot through the fence. A 70-200 on an APS-C camera is pretty narrow!
But you're not likely to 'remove' the fence from the equation, and going narrower (longer focal length) to shoot through the fence is likely to crop your subject too much.
Also: congrats on the new camera!
D
Guest
Well the problem is using a wider focal length the subject I am taking pictures of is well... doesn't take up enough "real estate" in the picture and I'd have to crop out a lot of the pixels to get the "picture frame" worthy image. If that makes any sense?
I'm thinking about asking the coach and umpire if I can just go on the other side of the fence. I mean, it's not like it's a serious game with 4 - 6 year olds playing t-ball ya know? lol
IdiotInCharge
NVIDIA SHILL
Yup. Best answer is to get on the other side of the fence. Second best is to get as close to the fence as possible; even touching it. Might not get the fence in the way at all, but also might need a wider lens for some shots.
Also, consider the 55-250 STM for daylight lower-intensity sports: I realize that there are few 'bad' 70-200 lenses (and none from Canon), but that lens really shows off the beauty of shooting on APS-C. Cheap, light, sharp, fast enough AF. Wider and longer and still capable of reasonable focus isolation. Can get refurbished from Canon with same warranty as new. Also might fit through the fence enough :).
Jim Kim
Impressive shots. I know nothing about photography and did not even notice the fence in the images until I read this.
