So I got my SSD today...
Irishllama
And my first question is...
Where the hell do you guys mount yours? I don't have any of the adapters
You probably should buy a 2.5-to-3.5 inch adapter for it. If you're feeling adventurous, you could get any type of 2.5" mount & put it anywhere in your PC. A normal adapter would see benefit if you have cooling for the 3.5" bays.
Velcro allows a variety of installation choices ...
I was thinking about Velcro, since I have some nice "Industrial" size Velcro. How warm does the SSD get? I just want to make sure it doesn't get TOO hot not having air flow on one side.
Not hot at all, velcro mount is a great idea. You can tuck it out of the way completely.
Mine floats loosely on the bottom of my full tower. At some point I will either Velcro it there or drill some holes so I can screw it to the bottom.
I just bolted it to one side of the 3.5" bays. I had to dremel out one of the holes just a bit (make it oval shape) so the screws would line up. It doesn't weigh anything, and there is no moving parts, so doesn't really need to be that secure.
Mines just chilling loose in a drive bay with a short sata cable so it cant flop around too much.
I use the "SILVERSTONE SDP08 3.5 to 2 X 2.5-Inch Bay Converter" and since I have 2 SSD's, I can fit them both in a 3.5 mount. Metal housing, nice and strong, side mounting screws, and comes with screws too. Fry's sells them locally for $10 or you can get it off NewEgg/Amazon for a bit under if you don't pay for shipping or tax.
I have mine mounted using 4 industrial strength round velco dots. It was the only velco I had around and it works great.
The 4 installations I've done (all in Silverstone SG-01/02 cases) have just been tucked into a 3.5" drive bay with other misc. cables tucked in there as well to wedge the SSD in place.
Velcro behind the drive cage. It's the best way to mount it in an A0 5B. The 5.25 btw, I took out the hard drive cage.
I just mounted it to a 3.5" drive tray of my case with 1 screw. Since it's a tray, this screw is not working against gravity. I would not do that without the tray.
