I am sending the cpu to motherboardrepair to hopefully get it repaired, but if it can't be fixed.. I'm looking for recommendations.
I don't quite want to do a full blown upgrade yet and would rather wait for AM2. I'm more than likely going to try an eBay off my current 512MBx2 of BH-5 and just order 1GBx2 of Corsair value or something similar. My main complaint with the current setup was that it tended to be a little slower with switching between applications with a game running and loading large areas in World of Warcraft. Do you think another 3000+ would be sufficient with the 2GB of ram or would something with a little more L2 be a better recommendation?
I repeat, I do not want to spend tooo much on this since I am planning for a full upgrade when AM2 comes out, so X2 is pretty much out of the question unfortunately.
Thanks
Thanks
