zygoat said:you'll get better cooling if the fan is on the outside pulling air off the rad
endscape said:Yes, your shuttle is now MY shuttle lol. A couple questions however. Is that a P4 Maze4? I was looking at it, and a Athlon block wouldnt mount, so I was just wondering before I buy a block.
I had another thought/comment/question, but I cant think of it right now.
Pics should be up tonight of the windows and what not that I put into it!
EDIT: http://www.hardforum.com/showthread.php?t=780468
Endscape
where should I look for this stuff? Arts and crafts kinda thing or home depot?darktiger said:I used extra strength 3m double side tape. Holds 5lbs per square inch. Also real good to use for pic frames instead of nails..
