SN25P usb problem
yanansi
hi
i got some problem about the usb2.0 hdd with sn25p. i cant write anything into the usb hdd. once i do the system notice me that there is a windows delayed write failed
i have no problem for using this usb hdd in the other two computer(a desktop and a laptop)
whats wrong with the sn25p?
cheers
is your drive powered from the USB or from a wall wort?
I've seen that problem from 2.5" external drives that weren't getting enough juice from the USB port.
Other than that, I'd look for new drivers or just try reinstalling the old ones.
Did you update the SN25P's BIOS? With an X2 CPU and the SN25P, you NEED to for USB2.0 to work properly.
the usb hdd is get power from usb port. but i have no problem with my laptop and the famliy desktop. what usb driver you taking about? i didt install any driver for the usb.in the device manager under universal serial bus controller:
--standard Enhanced PCI to USB Host
--standard OpenHCD USB Host
i didt see any usb2 there!
got the new y bios and i have a 146 atm.
