How many ppd is your C2D producing?My lappy with a C2D 7200 (2ghz) is pounding my x2 4600+ (2.4ghz) in the SMP client.
What about running the SMP client in VMWare, and adding a GPU client running in Windows? Is that permissible? Does it give a significant boost?
I also have 2 dedicated C2D SMP Linux (SUSE 10.2) machines and they
typically crank out 1200-1400 ppd.
For < $400 you can build a dedicated C2D SMP machine that will produce well over
1000 ppd.
wget http://ranume.radionet.ee/folding/finstall
chmod +x finstall
./finstall smp
sudo ./installservice
Yep. I'm doing that with my primary Windows XP machine. It's a C2D 6700 @ 3.4 GHz with a X1950XTX running the SMP client in VMWare along with the GPU client.
It varies, but in general that combo gives ~1800-2000 ppd.
VMWare only leaves about 20% CPU left for the GPU which hinders its performance
by ~30%, but it's still the best ppd option for a dual core cpu + high end GPU
running Windows.
Question: How long is it taking you to get through an SMP WU on average and a GPU WU on average? The GPU has a perfered return of 3 days, and the SMP anywhere from .75 to 2 days.
