Small plastic protrusions on eVGA 6800. Can I remove them?
Kyohe
So, I have an eVGA 6800. I also recently installed a new heatsink, that everyone says should have no clearance issue with my hardware. But it does, but only where it just barely touches these weird plastic protrusions on the edge of my card. Sorry, I can't get a picture of my own card, but I'll try to explain it as best I can.
All the pictures of 6800s I can find online don't have any protrusions like mine.
http://www.linuxhardware.org/images/articles/intel775a643800-091704/eVGA-GeForce-6800GT-top.jpg
For example. If you look to the right of the PCIe pins along the bottom edge of the card, you see that it's just a flat edge of plastic. On mine there are two symmetrical "nubs" that stick out maybe 2-3mm off the edge of the card. They point in the same direction as the pins, (toward the motherboard when installed). I don't see any traces on them or anything.
So, does anyone know what those are? And whether or not I can safely file them down? Thank you.
Even if they're tacked-on plastic, I'd be very careful sanding them down if they're so close to the PCIe pins. Probably wanna tape it up or something, wouldn't want any of that stuff going back into your PCIe slot on the mobo.
What heatsink did you install? You linked an AGP 6800 with a stock cooler. :p
I'm sorry, I should have made that clearer. I installed a new heatsink (an Evercool VC-RE Twinkling cooler) on the north bridge chip of my DFI Lanparty NF4. The inside edge (the one nearest the motherboard) of my 6800 is bumping into the top of the Northbridge heatsink. But only in the one spot where these protrusions are. I find it especially strange that all pictures of other cards I can find don't have this protrusion. Again, I wish I had a camera (sheesh). Thanks.
Is this what you mean?
The tab is just a piece of the PCB mean to hold the end of the board in place. The DFI board doesn't seem to use it the same way as other boards, so you could trim the tab to fit. It's probably out of warranty anyways.
No, it's past that tab and a fair amount smaller. Two, symmetrical squarish nubs. And they aren't in that picture of the card you have. That's the strange part. It's also strange how well formed and symmetrically placed they are. If they weren't I'd just assume they were plastic defects where it broke off the mold or something. They seem purposefully placed, but for what I can't even imagine.
Where did you get this card? Is it some ES "engineering sample" or something? Could you borrow a cam off someone or have someone take pics of it? We could help you more if we saw what it looked like.
It's just a standard eVGA 6800 that I bought off Newegg.com. I'll work on getting a picture up.
Alright, I got some images so I can show you folks what I'm talking about. Hopefully they aren't so big as to cause any problems. So here is my card:
And a couple close ups of the protrusions I'm talking about:
As you can see, it's just kind of there. And strange. Here are a couple of pics of my mobo, with and without card.
It's a bit blurry, but you can see the protrusion just barely touching the top of one of the fins. So, what do you think? Thanks.
I'm just guessing, but that stuff just looks like contact points from some sorta mold the PCB was cut out of... I've seen the same thing on any number of cards in the past, should be safe to sand down.
Yeah I say it's OK to file it down until it clears. Just take your time and be careful.
Cut'em off. Just extra PCB where they didn't do a good job getting them off originally (or didn't care).
Those pics arent just big, thier HUGE im on my 1920by1200 monitor and i STILL have to scroll, please size down!
but same as others, cut it off if u can
btw A program called Infranview can do a batch conversion and resize countless pictures with one click
You're right. Much easier to see now.
Sounds like we're in agreement that it's just weird and useless. I like the nail clipper idea, I might give it a try. I'll post again to tell you how it goes. Thanks.
Well, finger nail clippers worked great for removing the nubs. Here's what it looked like afterward:
and installed (blurry):
It seems to be clearing just fine now, though it's still a really close fit. I'm going to consider it fixed, but I'll post again if there's a problem. Thanks for the help folks, and happy holidays!
