Small network switch brand quality?
Discussion in 'Networking & Security' started by Valnar, Feb 25, 2019.
  1. Valnar
    Valnar 2[H]4U
    3,069
    Apr 3, 2001
    Hey everybody. I've been in the Enterprise space too long that I need a refresher on SOHO brands. Can anyone give me a general pecking order on brand quality between the common ones?
    Linksys
    Netgear
    D-Link
    TP-Link
    HP?
    Specifically, I'm looking for a 4-8 port PoE "barely-managed" (web-managed) switch that supports vlans. L2 is fine. I don't need L3.
    Thanks.
  2. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,607
    Jun 13, 2003
    All of the above have products in that space for not a whole lot. Most call it Layer 2+, or otherwise specifically mention VLAN support.
  3. Livewyre
    Livewyre n00b
    13
    Feb 23, 2016
    Ubiquiti is another brand you might want to look into.
  4. daglesj
    daglesj [H]ardness Supreme
    5,101
    May 7, 2005
    I've been buying TP-Link pretty much all the time.They have some what are called 'Easy Smart" that give you more control over a unmanaged.
    I like the fact you can go to their website and play around with the product emulators so you can check the functionality you want is there and also get up to speed before the product arrives.
  5. Valnar
    Valnar 2[H]4U
    3,069
    Apr 3, 2001
    I ended up ordering the TP-Link TL-SG108PE. It was pretty much the only choice.
  6. IdiotInCharge
    11,607
    Jun 13, 2003
    So long as you stay with their EdgeMax switches- their Unifi line is a bit 'needy' if you only need one device.
  7. waderunner
    waderunner [H]ard|Gawd
    1,027
    Jun 2, 2013
    This.
  8. PliotronX
    PliotronX 2[H]4U
    2,066
    Aug 8, 2000
    Check out the 8 port Zyxel GS1900 70W.
